1. Setting Up Pabbly Connect for Your AI Agent
To create an AI agent for your travel agency, the first step is to access Pabbly Connect. You can do this by visiting the Pabbly website and signing in to your account. If you are a new user, you can sign up for free and get 100 credits monthly to explore the features.
Once you log in, navigate to the Pabbly Connect dashboard. Here, you will find various options to integrate different applications. Pabbly Connect serves as the central platform that enables seamless integration between your WhatsApp and AI tools, allowing you to automate responses effectively.
2. Adding WhatsApp to Pabbly Connect
To integrate WhatsApp with your AI agent, you need to add your WhatsApp number to Pabbly Connect. Click on the ‘Add WhatsApp Number’ option and choose the preferred method for connection. You can connect via WhatsApp Connect or manually using a token.
  • Select ‘WhatsApp Connect’ for a seamless integration.
  • If manual connection is preferred, follow the provided steps to enter your token.
After successfully adding your WhatsApp number, you can proceed to create the AI agent. This integration allows Pabbly Connect to handle incoming messages and automate responses based on user queries.
3. Creating Your AI Agent in Pabbly Connect
Next, you will create your AI agent within Pabbly Connect. Navigate to the AI assistant section and click on ‘Add Assistant’. Name your assistant, for example, “Travel and Holiday Package Agent”. This is where the magic begins as you set the parameters for your AI agent.
In this section, you will configure the AI instructions and settings. Set the instruction type to AI agent and adjust the creativity level to your preference. The AI model to be used is OpenAI’s GPT-5 Mini, which will enhance the responses provided to users.
  • Select the creativity level between 0 (focused) and 1 (creative).
  • Enter your OpenAI API key to enable the AI functionalities.
Once you’ve configured these settings, your AI agent will be ready to handle queries effectively, providing detailed responses to customer inquiries.
4. Configuring AI Agent Settings in Pabbly Connect
To enhance the functionality of your AI agent, you must configure various settings in Pabbly Connect. This includes setting up greeting messages, fallback responses, and the stop keyword. The stop keyword allows users to escalate issues to human support if needed.
You can also set the number of retry attempts for the AI agent to respond to a query. This ensures that if the AI fails to respond, it will make additional attempts to provide an answer.
  • Define the fallback message for unresolved queries.
  • Set the retry attempts between 1 to 10 for maximum efficiency.
These configurations will ensure that your AI agent is robust and can handle various customer queries effectively, enhancing user experience.
5. Activating and Embedding Your AI Agent
After setting up your AI agent, the next step is to activate it in Pabbly Connect. Toggle the activation button to make your AI assistant live. You can also embed this AI agent into your website, allowing users to initiate WhatsApp conversations directly from your site.
To assign your AI assistant to specific chats or groups, navigate to the inbox settings. You can enable AI auto-replies for all contacts or specific groups, streamlining your customer interactions.
  • Choose the AI assistant from the settings menu.
  • Save your settings to finalize the integration.
By following these steps, you will have a fully functional AI agent that automates your WhatsApp conversations, providing timely responses and improving customer satisfaction.
In this tutorial, we explored how to create an AI agent for your travel agency using Pabbly Connect. By integrating WhatsApp and AI tools, you can automate customer interactions effectively. This setup enhances engagement and streamlines communication, making it a valuable addition to your business operations.
