To begin integrating See and So I, first, you need to access Pabbly Connect. Open your browser and navigate to pabbl.com/connect. If you’re new, click on the “Sign Up for Free” option in the top right corner. This allows you to explore Pabbly Connect with 100 free tasks monthly.
Once signed up, log into your account. You will see the dashboard where you can create workflows. This is crucial as Pabbly Connect will facilitate the automation between See and So I, ensuring a seamless integration process.
After logging into Pabbly Connect, click on “Create Workflow”. This is where you will set up the automation between See and So I. Name your workflow appropriately to reflect its purpose, making it easier to identify later.
- Click on the “Add Trigger” button.
- Select the appropriate trigger application, such as Form Builder.
- Choose “New Response” as the trigger event.
With this setup, Pabbly Connect will listen for new responses from your selected form builder. This is essential for capturing data automatically as it comes in.
3. Setting Up the Webhook in Your Form
Now that the trigger is set, you’ll need to configure the webhook in your form. Copy the webhook URL generated by Pabbly Connect and navigate to your form settings. Look for the integrations section and select “Webhooks”.
Paste the copied URL into the webhook settings and save it. This step connects your form to Pabbly Connect, enabling it to receive data whenever a new response is submitted. Make sure the integration is successful to avoid any issues later.
4. Capturing Responses and Creating Subscribers
After setting up the webhook, it’s time to test the integration. Submit a test response through your form. Once submitted, Pabbly Connect will capture the response data. You can view this in your workflow dashboard.
- Click on “Add Action Step”.
- Select the action application, such as Kit.
- Choose “Insert or Update Subscriber” as the action event.
This function allows you to create or update subscribers in your Kit account using the data captured by Pabbly Connect. Ensure that you map the fields correctly to reflect the data from your form.
Once you’ve configured the action step, review your settings and click “Save and Send Test Request”. This will send the captured data to your Kit account, creating a new subscriber. Refresh your subscriber list to confirm the addition.
With Pabbly Connect, you can automate this process, ensuring that every new form submission results in an instant update to your subscriber list, streamlining your workflow effectively.
In this tutorial, we explored how to integrate See and So I using Pabbly Connect. By following these steps, you can automate your workflows efficiently and enhance your business operations. Start using Pabbly Connect today to simplify your integration processes.
