To start using Pabbly Connect for automating WhatsApp follow-ups, first, access the platform by visiting the Pabbly Connect website. Create your account if you haven’t already. Once logged in, you will be directed to the dashboard where you can begin setting up your workflows.
Within the dashboard, locate the option to create a new workflow. This is where you will define the integration between your applications. Ensure that you have both Pabbly Chat Flow and Pabbly Chatbot ready for integration as they will be crucial for the follow-up automation process.
2. Creating the Chat Flow in Pabbly Chat Flow
Next, navigate to Pabbly Chat Flow to create a flow that will handle user interactions. Select the “Flows” option from the left sidebar to access the flow builder. Here, you will create a new flow that will respond to user messages, such as greetings.
  • Choose a trigger event, like keyword matching, to start the flow.
  • Use the text node to send a welcome message when a user initiates a conversation.
  • Create buttons for user responses, such as “Book Appointment”.
After setting up the initial greeting and buttons, you can proceed to add more elements to your flow. This includes options for users to select treatments and schedule appointments, which will be handled by Pabbly Connect as the integration hub.
3. Adding Appointment Options in Pabbly Chatbot
In this section, you will define the appointment options that users can select. Utilize the list node to present available treatments. This involves dragging the list node into your flow and populating it with treatment options.
Make sure to specify a custom field for each treatment option. This custom field will help you track user selections. Once a user selects a treatment, the flow will guide them to choose a date and time for their appointment.
  • Use a date and time node to allow users to select their preferred appointment date.
  • Set the available time slots for each date, ensuring users can choose from multiple options.
These selections will be captured and processed through Pabbly Connect, allowing for seamless scheduling and confirmation of appointments.
4. Confirming Appointments with Pabbly Connect
Once the user has selected their appointment details, it’s time to confirm their booking. Use the text button node to send a confirmation message that includes all their chosen details. This message should reassure the user that their appointment is successfully booked.
After sending the confirmation, implement a delay node to send a follow-up message. This delay can be adjusted based on your preference, allowing you to choose how long after the appointment confirmation the follow-up message will be sent.
For example, set a delay of one minute to send a follow-up message that reminds the user of their appointment details. This automation is facilitated entirely through Pabbly Connect, ensuring that users receive timely reminders without manual intervention.
5. Finalizing the Flow and Testing
After configuring all the necessary nodes and actions, save your flow in Pabbly Chat Flow. This will ensure that your automation is active and ready to handle incoming messages.
It’s essential to test your flow to ensure that everything functions as expected. Send a test message to your WhatsApp number to see if the bot responds correctly and follows the intended flow. Adjust any settings as needed based on the test results.
By using Pabbly Connect, you can automate the entire process, from initial greetings to appointment confirmations and follow-ups, making your customer interactions seamless and efficient.
In this tutorial, we explored how to automate WhatsApp follow-ups using Pabbly Connect, Pabbly Chat Flow, and Pabbly Chatbot. By following these steps, you can enhance customer engagement and ensure timely communications effortlessly.
