To integrate WhatsApp with Pabbly Connect, start by accessing Pabbly Connect. This platform allows you to create automated workflows without any coding skills. Log in to your Pabbly account or sign up for free to get started.
Once logged in, you will receive 100 free credits to test your integrations. Navigate to the dashboard and look for the option to create a new workflow. This is where you will set up the connection between WhatsApp and your desired applications.
2. Creating Your WhatsApp Assistant Using Pabbly Connect
To create your WhatsApp assistant, go to the “Assistant” section in Pabbly Connect. Click on the “Add Assistant” button to open a new window where you can configure your assistant. Here, you will need to name your assistant and select the type of AI agent you wish to use.
  • Choose the AI agent type for your assistant.
  • Configure the settings such as temperature and model.
  • Upload necessary documents related to your business.
After configuring your assistant, ensure that you set the response style according to your business needs. This allows your assistant to provide accurate and relevant responses to customer inquiries.
3. Configuring Assistant Settings in Pabbly Connect
In this section, you will configure the settings for your WhatsApp assistant. This includes setting up header and footer messages, stop keywords, and fallback messages. The fallback message is crucial; it ensures that if the API fails, your customers receive a predefined response.
Make sure to toggle the settings according to your preferences. The header message can introduce your assistant, while the footer message can include additional information about your services.
  • Define the header and footer messages clearly.
  • Set up stop keywords to manage conversations effectively.
  • Create fallback messages to handle API failures.
These settings will enhance the interaction quality between your customers and the assistant, ensuring a seamless experience.
4. Activating Your WhatsApp Assistant in Pabbly Connect
After configuring all settings, it’s time to activate your WhatsApp assistant. Click the “Activate” button in Pabbly Connect to make your assistant live. Once activated, you will receive an embed code that you can use on your website.
Copy this embed code and integrate it into your website to allow customers to interact with your assistant directly through WhatsApp. This integration enables automated responses to customer inquiries without human intervention.
Now, whenever a customer sends a message, your assistant will automatically respond based on the configured settings. This saves time and enhances customer satisfaction.
5. Managing Customer Inquiries with Pabbly Connect
To effectively manage customer inquiries, navigate to the settings section in Pabbly Connect. Here, you can enable the inbox settings to automatically assign incoming messages to your assistant. This ensures that all customer messages are handled efficiently.
Scroll down to the inbox settings and enable the option to assign contacts to your assistant. This way, when customers send messages, they will receive timely responses without delay.
By utilizing these features, you can automate your customer service and focus on growing your business. This integration with WhatsApp through Pabbly Connect streamlines communication and enhances overall efficiency.
Integrating WhatsApp with Pabbly Connect allows you to create a powerful assistant for your business. This setup automates responses and enhances customer interaction, making it easier to manage inquiries effectively.
