To start integrating WhatsApp with Pabbly Connect, you first need to visit Pabbly’s website. Search for Pabbly.com in your browser, which will direct you to the homepage. Here, you will find options to either sign in or create a free account.
If you are a new user, click on “Sign Up Free” to explore the features of Pabbly Connect. Existing users can simply log in to access their dashboard. Make sure to take advantage of any special discount codes available for new subscriptions.
2. Creating Your WhatsApp AI Chatbot with Pabbly Connect
Once logged into Pabbly Connect, navigate to the AI Assistant feature. This is where you can create your WhatsApp chatbot. Click on the “Add” button to create a new assistant, and give it a suitable name.
  • Select the instruction type from the dropdown menu.
  • Choose predefined examples like AI Agent or Customer Support Agent.
  • Set the creativity level for responses using the temperature setting.
After selecting the instruction type, configure the AI settings to tailor the chatbot’s responses. This customization enhances user interaction through Pabbly Connect.
3. Setting Up API Keys in Pabbly Connect
To enable your WhatsApp chatbot, you need to set up API keys within Pabbly Connect. This involves creating a new secret key in your OpenAI account. Click on the hyperlink provided in the Pabbly dashboard to access the API key settings.
Once you are in the API settings, click on “Create New Secret Key”. Name your key and select the project. After creating the key, copy it and paste it back into your Pabbly Connect assistant settings. This step is crucial for connecting your chatbot with WhatsApp.
4. Configuring Chatbot Settings in Pabbly Connect
Now that your API key is set up, it’s time to configure the chatbot settings in Pabbly Connect. You can add a header message, footer message, and specify stop keywords for the assistant. This customization allows you to control the chatbot’s behavior effectively.
  • Enter a header message to greet users.
  • Add footer text to provide additional information.
  • Specify keywords that will trigger the assistant to stop responding.
After configuring these settings, make sure to save your changes. This will enhance the functionality of your WhatsApp chatbot through Pabbly Connect.
5. Assigning Your Chatbot to WhatsApp Chats
Finally, to make your WhatsApp chatbot operational, you need to assign it to specific contacts or groups. Go to the inbox settings in Pabbly Connect and enable the auto-reply feature. Select the contact list or specific chats where the assistant will be active.
Click on the “Save” button to finalize the assignment. This step ensures that your WhatsApp chatbot is ready to respond to customer inquiries automatically, enhancing your business communication.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect to create an efficient AI chatbot. By following these steps, you can enhance customer interaction and streamline your business processes.
