To start integrating WooCommerce with WhatsApp, first access Pabbly Connect. Open your browser and type in the URL pabbly.com/connect to reach the Pabbly Connect dashboard.
Once on the dashboard, you can either sign up for a free account or log in if you are an existing user. New users can benefit from 100 free tasks monthly to explore the platform, making it easy to test the integration.
After logging into Pabbly Connect, click on the “Create Workflow” button to initiate a new automation process. This will allow you to set up the integration between WooCommerce and WhatsApp.
- Select “Quick Builder” for a streamlined setup.
- Enter the prompt: “Integrate WooCommerce with WhatsApp”.
- Choose the trigger as “New Order Created” from WooCommerce.
Once you’ve set up the trigger, select the WhatsApp Cloud API as the action application. This will enable Pabbly Connect to send WhatsApp messages based on WooCommerce order events.
3. Setting Up Webhook for WooCommerce
The next step in using Pabbly Connect is to set up the webhook in WooCommerce. Copy the webhook URL generated by Pabbly Connect, as this will act as a bridge between WooCommerce and Pabbly.
Now, navigate to your WordPress dashboard and go to WooCommerce settings. Here are the steps to add the webhook:
- Go to WooCommerce > Settings > Advanced > Webhooks.
- Click on “Add Webhook” and fill in the details.
- Set the status to “Active” and enter the copied webhook URL.
After saving the webhook, Pabbly Connect will be able to receive order data from WooCommerce whenever a new order is placed.
4. Mapping Data for WhatsApp Messages
With the webhook set up, the next step is to map the order data in Pabbly Connect. This involves specifying the recipient’s mobile number and the message content for WhatsApp notifications.
In the WhatsApp Cloud API section of Pabbly Connect, enter the required fields:
- Map the recipient’s phone number from the WooCommerce response.
- Compose the message, incorporating dynamic fields like the customer’s name and purchased product.
Once everything is set, click on “Save and Send Test Request” to ensure that the WhatsApp message is sent correctly. You should see a confirmation message in your WhatsApp, demonstrating successful integration.
Now that the integration is complete, it’s time to test it out. Go back to your WooCommerce store and place a new order for a product. After completing the checkout process, check your WhatsApp for the confirmation message.
If everything is set up correctly, you will receive a WhatsApp message thanking you for your order, along with the product details. This confirms that Pabbly Connect is functioning as intended, automating the process efficiently.
This integration not only saves time but also enhances customer communication, ensuring that your clients receive instant updates without any manual effort.
In this tutorial, we explored how to integrate WooCommerce with WhatsApp using Pabbly Connect. This automation streamlines order notifications, enhancing customer experience and saving time for business owners.
