Learn how to create a WhatsApp chatbot for astrology and horoscope help using Pabbly Chatflow. Follow our detailed tutorial for step-by-step guidance. Learn step-by-step how to create, test, and optimize chatbots that enhance customer experience while reducing support workload.
1. Accessing Pabbly Chatflow for Your WhatsApp Chatbot
To create a WhatsApp chatbot for astrology and horoscope help, start by accessing Pabbly Chatflow. Simply type the URL Pabbly.com/chatflow in your browser to reach the platform.
Once on the landing page, you will see options for signing in or signing up. If you are a new user, click on the ‘Sign Up Free’ button. Existing users can sign in directly. Signing up gives you 100 free credits each month for using Pabbly Chatflow.
2. Creating the Chatbot Flow in Pabbly Chatflow
After signing in, navigate to the dashboard of Pabbly Chatflow. Here, you will see various options, but for creating a WhatsApp chatbot, click on the ‘Flows’ option in the sidebar.
- Click on the ‘Add Flow’ button.
- Name your flow, e.g., ‘Astrology and Horoscope Consultation Bot’.
- Set the trigger event to ‘Keyword Regex Match’.
This setup allows your chatbot to initiate when a user sends a specific keyword, such as ‘astrology consultation.’ Once set, you can proceed to create the welcome message and buttons for user interaction.
3. Testing Your WhatsApp Chatbot
Once your flow is created in Pabbly Chatflow, it’s time to test the automation. Open WhatsApp and send a message like ‘I need astrology consultation’ to your business number.
Upon receiving the message, your WhatsApp chatbot will respond with a welcome message, including options like ‘Astrology Services’ and ‘Contact Support’. This confirms that the chatbot is functioning as intended. Now, selecting any option will lead to further interactions based on the flow you created.
4. Configuring Astrology Services and Consultations
In this step, you will configure the astrology services offered through your WhatsApp chatbot using Pabbly Chatflow. After the welcome message, provide a list of services users can select from.
- Create a list node for astrology services.
- Add items like ‘Horoscope Reading’ and their respective pricing.
- Use contact custom fields to store user responses.
Ensure that each service option leads to a confirmation message, indicating that the user’s request has been received. This enhances user experience and keeps them informed.
5. Finalizing and Sharing Your Chatbot
After configuring all elements of your WhatsApp chatbot in Pabbly Chatflow, save your flow to avoid losing any settings. You can then test the entire flow by sending messages and ensuring the responses are accurate.
Once satisfied, you can share your flow with others. Click on the three dots next to your flow and select the ‘Share Flow’ option to generate a link. This allows others to use your chatbot setup as a reference for their own automation needs.
In this tutorial, we explored how to create a WhatsApp chatbot for astrology and horoscope help using Pabbly Chatflow. By following the steps outlined, you can set up a functional chatbot that enhances user engagement and provides valuable services in real-time.
