Learn how to seamlessly sync WooCommerce products with Facebook Pages using Pabbly Connect in this comprehensive step-by-step tutorial. Discover how to seamlessly connect your essential tools through accessible instructions that make powerful automation available to professionals at every skill level.
1. Introduction to Pabbly Connect for WooCommerce and Facebook Pages
In this tutorial, we will explore how to use Pabbly Connect to sync WooCommerce products with Facebook Pages. This integration allows you to automatically share new products added to your WooCommerce store on your Facebook Pages seamlessly.
To start, you will need a Pabbly Connect account. Once you log in, you can create workflows that connect your WooCommerce store with your Facebook Pages. This setup ensures that every time you add a product, it is automatically posted to your selected Facebook Pages.
2. Setting Up Your Workflow in Pabbly Connect
First, access your Pabbly Connect dashboard and click on the blue button labeled ‘Create Workflow’. Here, you will name your workflow, such as ‘Sync WooCommerce Products with Facebook Pages’. After that, select the folder where you want to save this workflow. using Pabbly Connect
- Click on ‘Create’ to start building your automation.
- You will see two boxes: Trigger and Action.
- Select WooCommerce as your Trigger application.
Now, choose the trigger event, which is ‘New Product Created’. This event will initiate the workflow whenever a new product is added to your WooCommerce store. After selecting this, you will receive a webhook URL that you need to copy for the next steps.
3. Connecting WooCommerce to Pabbly Connect via Webhooks
To connect WooCommerce with Pabbly Connect, navigate to your WooCommerce dashboard. Go to Settings, then Advanced, and find the Webhooks option. Here, you will create a new webhook by pasting the copied webhook URL from Pabbly Connect.
- Name your webhook, e.g., ‘Connection with Pabbly Connect’.
- Set the status to Active.
- Select the topic as ‘Product Created’.
After saving the webhook, you will see a confirmation that the webhook has been successfully created. This means that WooCommerce is now connected to Pabbly Connect, allowing it to send data whenever a new product is added.
4. Posting Products to Facebook Pages Using Pabbly Connect
Now that WooCommerce is connected to Pabbly Connect, the next step is to share the product information on Facebook Pages. In your Pabbly Connect workflow, add an Action step and select Facebook as the application. Choose the action event ‘Create Page Photo Post’.
Connect your Facebook account by clicking ‘Add New Connection’. Once connected, you will see all your Facebook Pages listed. Select the page where you want to post the product. Next, you will need to map the product details from the WooCommerce trigger to the Facebook post, including the photo URL and product description.
Map the image URL from the WooCommerce product details. Add a description that includes a link to the product. Ensure all details are correctly mapped for the automation to work.
After setting up the mapping, click on ‘Save and Send Test Request’. If successful, the product will be posted to your selected Facebook Page automatically.
5. Sharing Products on Multiple Facebook Pages with Pabbly Connect
To share products on multiple Facebook Pages, you can duplicate the Action step in your Pabbly Connect workflow. Click on the plus icon to add another Action step for Facebook. using Pabbly Connect
Repeat the process of selecting the Facebook Page and mapping the product details. You can rename each Action step for clarity, such as ‘Dress Shop’, ‘Ashid Garments’, and ‘Your Daily Fashion’. This way, you can manage multiple pages effectively within a single workflow.
Refresh the pages list to ensure all your Facebook Pages are visible. Test each Action step to confirm that posts are being shared correctly. Once completed, products will be shared on all selected pages automatically.
This method allows you to automate the process of sharing your WooCommerce products across multiple Facebook Pages, saving you time and effort.
In this tutorial, we demonstrated how to sync WooCommerce products with Facebook Pages using Pabbly Connect. By following these steps, you can automate the sharing process and enhance your online marketing efforts efficiently.
