To start integrating your WhatsApp Chatbot, first access Pabbly Connect. This platform will serve as the backbone for all your automation needs. Begin by visiting the Pabbly Connect website and signing in or creating a new account.
Once logged in, you will be directed to the dashboard. From there, you can create a new workflow that will connect various applications, including your WhatsApp Chatbot. Pabbly Connect ensures that all your apps communicate seamlessly.
2. Setting Up Pabbly Chatflow for WhatsApp Integration
Next, navigate to Pabbly Chatflow to set up your WhatsApp Chatbot. Click on ‘Access Now’ to enter the Chatflow dashboard. Here, you will need to add your WhatsApp number to start creating your chatbot.
  • Click on the ‘Flows’ section.
  • Select ‘Add Flow’ to create a new chatbot.
  • Choose a trigger event, such as ‘Keyword Match’ for your chatbot.
After setting the trigger, you can customize your chatbot’s responses. This step is crucial as it allows your customers to interact with the bot effectively, ensuring a smooth lead management process through Pabbly Connect.
3. Designing Chatbot Responses with Pabbly Chatflow
In this section, you will design the responses of your WhatsApp Chatbot. Start by dragging and dropping the text message feature to create a welcome message. This initial interaction sets the tone for customer engagement.
Next, add quick reply buttons to give users options. For example, you can provide buttons for exploring properties, booking site visits, or talking to an advisor. Each button should trigger a different series of questions, allowing you to gather important information from your leads.
  • Add questions to capture user inputs like city, property type, and budget.
  • Use contact custom fields to store the data provided by customers.
By utilizing Pabbly Chatflow, you can ensure that all customer responses are collected and sent to Pabbly Connect for further processing, helping you manage leads efficiently.
4. Connecting Pabbly Chatflow with Pabbly Connect
Once your chatbot is designed, the next step is to connect it with Pabbly Connect. This integration allows you to automate workflows based on the data collected from your chatbot. Start by creating a new workflow in Pabbly Connect.
Set the trigger application to Pabbly Chatflow and select the event for receiving new messages. This step is essential for ensuring that every interaction within your WhatsApp Chatbot is captured and processed automatically.
  • Paste the webhook URL into your Pabbly Chatflow settings.
  • Test the connection to ensure data is flowing correctly.
This integration between Pabbly Chatflow and Pabbly Connect allows you to automate responses and manage leads more effectively, ensuring no potential customer goes unattended.
5. Automating Responses and Managing Leads
Finally, automate responses based on the customer data received through Pabbly Connect. You can set up actions to fetch property details from Google Sheets or any other application that holds relevant data.
For instance, when a customer expresses interest in a property, use OpenAI to generate personalized messages based on their preferences. This automation ensures that your leads receive timely and relevant information.
  • Map customer preferences to fetch matching properties.
  • Send automated messages via WhatsApp using Pabbly Chatflow.
By leveraging Pabbly Connect in this manner, you can significantly improve your lead management process, ensuring that every inquiry is handled promptly and efficiently.
In summary, integrating WhatsApp Chatbot with Pabbly Connect allows for effective real estate lead management. By following the steps outlined, you can automate responses and ensure no lead goes cold. This system enhances your customer engagement and streamlines your workflow.
