Learn how to set up automation for multiple products in Razorpay using Pabbly Connect. This detailed tutorial covers all steps to integrate seamlessly with Google Drive.
1. Accessing Pabbly Connect to Set Up Automation
To set up automation for multiple products in Razorpay, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in or creating a new account. If you’re new, registering gives you 100 free tasks every month to explore the platform.
Once logged in, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Set Up Automation for Multiple Products in Razorpay’. Select an appropriate folder to save your workflow.
The next step involves setting up a trigger in Pabbly Connect. For this automation, select Razorpay as your trigger application. This will initiate the workflow when a payment is captured. Choose the trigger event as ‘Payment Captured’ to ensure the workflow activates upon successful payment.
- Select Razorpay as the trigger application.
 - Choose the trigger event ‘Payment Captured’.
 - Paste the webhook URL in the Razorpay dashboard under ‘Webhooks’.
After pasting the URL, select the event ‘Payment Captured’ and save the webhook. This establishes a connection between Razorpay and Pabbly Connect, allowing data transfer upon payment capture.
3. Testing the Trigger and Receiving Data
Once the webhook is set up, it’s time to test the trigger in Pabbly Connect. Make a test payment through your Razorpay payment page to generate a sample response. This step is crucial as it verifies that the connection is working correctly, capturing payment details.
After the test payment is made, return to Pabbly Connect where you should see the webhook response displayed. This response includes all relevant payment information like the order ID, customer details, and payment status.
- Verify the payment status in the webhook response.
 - Check customer details such as name, email, and phone number.
 - Confirm the amount received matches the course price.
With the data received, you can now proceed to set up actions based on the payment details captured.
4. Setting Up Actions in Pabbly Connect
In this section, you will configure the actions in Pabbly Connect based on the payment received. Use the Router feature to create different routes for each product. For example, if a payment of 9990 is received, it corresponds to the Digital Dynamics course, while a payment of 3990 corresponds to the Java notes.
Set up the Router by selecting it as your action application. Create conditions that check the payment amount and direct the workflow to the appropriate route. This way, you can automate the sharing of course materials based on the specific product purchased.
Select Router as the action application. Define conditions based on payment amounts. Add action steps to share course materials from Google Drive.
After setting up the Router, you can add specific actions for Google Drive to share the relevant course files with the customer based on the payment received.
5. Finalizing the Automation Workflow
Now that you’ve set up the triggers and actions in Pabbly Connect, it’s time to finalize the workflow. Make sure to test the entire process by making payments for both courses. This will ensure that the automation is functioning correctly and that customers receive access to the appropriate materials.
Upon successful testing, the workflow will automatically share the course PDFs from Google Drive with the customer’s email based on their purchase. This automation saves time and minimizes manual effort, allowing you to focus on other areas of your business.
Test the workflow by making payments for both courses. Ensure the correct files are shared with the respective customers. Monitor the workflow for any errors and adjust as necessary.
With everything set up, you can now efficiently manage your digital course sales through Razorpay using Pabbly Connect.
In this tutorial, we explored how to set up automation for multiple products in Razorpay using Pabbly Connect. By integrating Razorpay with Google Drive, you can automate the sharing of digital course materials effortlessly. This process not only improves efficiency but also enhances customer satisfaction.
