Learn how to send Diwali wishes to thousands of clients on WhatsApp using Pabbly Connect. This step-by-step guide covers integration with Google Sheets and 360 Dialogue.
1. Accessing Pabbly Connect for Sending Diwali Wishes
To send Diwali wishes to thousands of clients on WhatsApp, start by accessing Pabbly Connect. This platform allows seamless integration between various applications, making your automation process smooth and efficient.
Begin by visiting the Pabbly website. Click on the ‘Products’ tab and select Pabbly Connect. If you’re a new user, click on ‘Sign up for free’ to create an account. Once logged in, access the Pabbly Connect dashboard to start setting up your workflow.
After logging into your Pabbly Connect account, you need to create a new workflow. Click on the ‘Create Workflow’ button located at the top right corner of the dashboard.
When prompted, name your workflow, for example, ‘Send Diwali Wishes to Clients on WhatsApp’. This step is crucial as it helps you identify your workflow later. After naming, click on ‘Create’ to proceed. Your workflow is now ready for configuration.
- Click ‘Create’ to finalize.
With your workflow created, you can now begin integrating the necessary applications to automate the sending of Diwali wishes.
3. Integrating Google Sheets with Pabbly Connect
The next step is to integrate Google Sheets with Pabbly Connect. This allows you to pull customer data from your spreadsheet, which contains the contact information of clients you wish to send wishes to.
Search for ‘Google Sheets’ in the application field and select it. Choose the action event ‘Get Rows’ and connect your Google Sheets account. This will enable Pabbly Connect to access your customer data effectively.
- Select ‘Google Sheets’ as your application.
- Choose ‘Get Rows’ as the action event.
- Connect your Google Sheets account.
Once connected, specify the spreadsheet name and range of data you want to retrieve. This setup is crucial for ensuring that the correct client information is sent during the WhatsApp messaging process.
4. Sending Diwali Wishes via WhatsApp Using 360 Dialogue
After retrieving the client data from Google Sheets, the next step involves sending the Diwali wishes through WhatsApp. However, since WhatsApp does not allow direct messaging through its API, you will use 360 Dialogue as the intermediary.
In your Pabbly Connect workflow, search for ‘360 Dialogue’ and select it. Choose the action event ‘Send Template Message’. Here, you will need to enter your API key and domain from your 360 Dialogue account to establish the connection.
Select ‘360 Dialogue’ as your application. Choose ‘Send Template Message’ as the action event. Enter your API key and domain for authentication.
By completing this step, you can now send personalized Diwali wishes to each client in your list, enhancing your customer engagement during the festive season.
5. Conclusion
In conclusion, using Pabbly Connect to send Diwali wishes to thousands of clients on WhatsApp is a straightforward process. By integrating Google Sheets and 360 Dialogue, you can automate the sending of personalized messages efficiently.
This method not only saves time but also ensures that no client is left behind in your festive greetings. Start using Pabbly Connect today to enhance your customer communication strategies during special occasions like Diwali.
