Learn how to send affiliate links from Telegram to LinkedIn, Twitter, and Facebook using Pabbly Connect in this detailed tutorial. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To send affiliate links from Telegram to various platforms, you first need to access Pabbly Connect. Start by visiting the Pabbly Connect website and either sign in or create a free account if you don’t already have one. This process is quick and allows you to automate tasks efficiently.
Once logged in, you will be directed to the Pabbly Connect dashboard. Here, you can create workflows that automate your processes. Click on the ‘Access Now’ button under Pabbly Connect to proceed with setting up your integration.
After accessing Pabbly Connect, the next step is to create a new workflow. Click on the blue ‘Create Workflow’ button. You will be prompted to name your workflow, so enter a descriptive title like ‘Send Affiliate Links from Telegram to Various Platforms’.
- Select a folder to save your workflow.
- Click on ‘Create’ to initiate your workflow.
This will bring you to the workflow setup window where you can define triggers and actions. The trigger will be set to Telegram, while the actions will be directed to Facebook, Twitter, and LinkedIn.
3. Setting Up the Telegram Trigger
In this step, you will configure the Telegram trigger in Pabbly Connect. Search for Telegram in the trigger application section and select it. Then, choose the trigger event as ‘Set Webhook Slash Updates’. This will allow Pabbly Connect to listen for new affiliate links posted in your Telegram channel.
To connect your Telegram account, you will need a token. Follow these steps to obtain it:
- Open Telegram and search for ‘BotFather’.
- Create a new bot by following the prompts and copy the generated token.
Paste the token into Pabbly Connect and click on ‘Save’. This establishes a successful connection between your Telegram account and Pabbly Connect.
4. Sending Messages to Social Media Platforms
Now that the trigger is set, it’s time to send the affiliate links to social media platforms using Pabbly Connect. Begin by creating an action step for Facebook. Search for Facebook Pages, and select the action event as ‘Create Page Post’. Connect your Facebook account and authorize the application.
Next, map the necessary fields for the Facebook post:
Select your Facebook page. Map the message and link URL from the Telegram trigger response.
Repeat similar steps for LinkedIn and Twitter, ensuring that you select the appropriate action events and map the data accordingly. This allows you to post the same affiliate message across all chosen platforms seamlessly.
5. Finalizing and Testing the Integration
After setting up the actions for Facebook, LinkedIn, and Twitter, it’s crucial to test the integration in Pabbly Connect. Click on the ‘Save and Send Test Request’ button for each action step to confirm that posts are being created successfully on each platform.
To verify, check your social media accounts. You should see the affiliate link message posted on Facebook, LinkedIn, and Twitter. This confirms that your integration is working as intended and that you can now automate the posting of affiliate links from Telegram.
In this tutorial, we demonstrated how to use Pabbly Connect to send affiliate links from Telegram to various platforms like LinkedIn, Twitter, and Facebook. By following these steps, you can automate your social media postings, saving time and effort while maximizing your outreach.
