To start integrating WhatsApp with Pabbly Connect, first open your web browser and navigate to the Pabbly Connect website. Here, you can sign in or create a new account if you are a first-time user.
Once logged in, you will be directed to the dashboard. Look for the option to access Pabbly Connect, which is essential for setting up your integrations with WhatsApp. Ensure that you have your WhatsApp number ready for the next steps.
2. Creating an AI Assistant with Pabbly Chatflow
After accessing Pabbly Connect, the next step is to create an AI assistant using Pabbly Chatflow. Click on the “Add Assistant” button to initiate this process. You will be prompted to enter a meaningful name for your assistant, such as “After Sales Retention Assistant”.
- Name your assistant appropriately.
- Select the AI agent type from the dropdown.
- Provide specific instructions for the AI assistant.
This assistant will help manage customer inquiries and prevent refunds by providing immediate support. After naming your assistant, click on the “Add Assistant” button to proceed to the configuration settings.
In this section, you’ll configure the AI settings for your assistant. Begin by selecting the instruction type as “AI Agent”. This will allow you to define how the assistant interacts with users. You can set the creativity level of the AI’s responses by adjusting the temperature setting.
Next, connect your AI to OpenAI by entering your API key, which you can obtain from your OpenAI account. Make sure to save these settings before moving on. This configuration is crucial for allowing the AI to respond accurately to customer queries.
4. Uploading Knowledge Base for Customer Support
To enhance the capability of your AI assistant, upload a knowledge base that includes FAQs and company information. This can be done by dragging and dropping a text or PDF file into the designated area in Pabbly Connect.
- Ensure your file is less than 90MB.
- Use .txt or .pdf formats for your knowledge base.
- Include detailed information that the AI can use to answer queries.
Once uploaded, this knowledge base acts as the brain of your AI assistant, allowing it to provide accurate and relevant responses to customer inquiries.
5. Testing the WhatsApp Integration with Pabbly Connect
To ensure that your AI assistant is functioning correctly, it’s crucial to test the integration. You can do this by sending a predefined keyword, such as “support”, through your WhatsApp account. This will trigger the AI assistant you created.
After sending the keyword, observe how the assistant responds. It should provide a welcome message and assist you based on the options available. This testing phase is vital to confirm that your setup is working smoothly and that the assistant is effectively managing customer interactions.
In this tutorial, we explored how to integrate WhatsApp with Pabbly Connect to create an AI assistant that enhances customer support. This process not only automates responses but also helps retain customers by addressing their concerns promptly.
