Learn how to automate LinkedIn posting using Pabbly Connect and Perplexity AI for enhanced reach in 2026. Step-by-step tutorial included. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To automate your LinkedIn posts using Pabbly Connect, start by visiting the Pabbly website. Here, you can sign in if you’re an existing user or sign up for free to explore the platform.
Once logged in, navigate to the Pabbly Connect dashboard. This is where you will create a new workflow that integrates LinkedIn with Perplexity AI and Google Sheets. The process is straightforward and user-friendly, allowing you to set up automation efficiently.
After accessing Pabbly Connect, click on the ‘Create Workflow’ button. Choose the new beta workflow builder for a modern experience. Name your workflow something descriptive, like ‘Perplexity AI for LinkedIn Auto Posting System for 10x Reach in 2026’.
  • Select your workflow folder.
  • Set the trigger application to Google Sheets.
  • Select the trigger event as ‘New or Updated Spreadsheet Row’.
With this setup, every time you add a new title in Google Sheets, it will trigger the workflow in Pabbly Connect, leading to automatic content generation and posting on LinkedIn.
To connect Google Sheets with Pabbly Connect, you’ll need to set up a webhook. Copy the webhook URL provided in your workflow and open your Google Sheets. Navigate to Extensions > Add-ons > Get Add-ons, and search for ‘Pabbly Connect Webhooks’ to install it.
  • Paste the webhook URL in the Pabbly Connect Webhooks setup dialog.
  • Set the trigger column to the final data entry column, such as Column D.
  • Test the connection to ensure data is sent to Pabbly Connect.
Once the connection is established, any new data added to your specified column will automatically trigger the workflow in Pabbly Connect.
4. Generating Content with Perplexity AI
Next, you will integrate Perplexity AI into your workflow via Pabbly Connect. Add a new action step, select Perplexity AI, and choose the action event as ‘Create Chat Completion’. Connect your Perplexity AI account by entering your API token.
In the setup, you will define the prompt for content generation. For instance, you might say, ‘You are an expert content creator for LinkedIn who generates engaging posts based on the input data provided.’ This prompt will guide Perplexity AI to create relevant content for your LinkedIn posts.
5. Posting to LinkedIn Using Pabbly Connect
Once the content is generated, the final step is to post it to LinkedIn through Pabbly Connect. Add another action step, select LinkedIn, and choose the action event as ‘Share Simple Text’. Connect your LinkedIn account by entering your credentials.
Map the content generated by Perplexity AI into the LinkedIn post content field. Set the visibility to Pabbly, and save the configuration. Now, whenever a new title is added to your Google Sheets, Pabbly Connect will automatically generate content using Perplexity AI and post it to your LinkedIn profile.
Utilizing Pabbly Connect for automating LinkedIn posts with Perplexity AI enhances your online presence significantly. This integration allows for efficient content generation and posting, saving time while maximizing reach.
