Learn how to automate your tasks using Pabbly Connect with this step-by-step tutorial, integrating Google Forms and WhatsApp seamlessly. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To start using Pabbly Connect, open a new tab and enter the URL Pabbly.com/connect. This will take you to the homepage of Pabbly Connect where you can sign up or log in.
If you are a new user, click on the ‘Sign Up Free’ option. This allows you to create an account that gives you access to 100 free tasks every month. For existing users, simply click on ‘Sign In’ to access your account.
2. Creating Your First Workflow in Pabbly Connect
Once logged into Pabbly Connect, navigate to the dashboard. Here, you can see all your workflows organized in folders. To create a new workflow, click on the ‘Create Workflow’ button.
  • Select the modern workflow builder for better flexibility.
  • Name your workflow, e.g., ‘Send WhatsApp Messages to Google Form Leads’.
  • Choose a folder to save your workflow for better organization.
After naming your workflow, click on the ‘Create’ button to proceed to the workflow page where you can set up triggers and actions.
3. Setting Up a Trigger in Pabbly Connect
In this step, you will set up a trigger that initiates your workflow. For this integration, select ‘Google Forms’ as your trigger app. Click on ‘Add Trigger’ and choose the event ‘New Response Received’.
  • Connect your Google account to allow Pabbly Connect to access your forms.
  • Copy the provided webhook URL to link Google Forms with Pabbly Connect.
  • Set up the trigger column in your Google Sheet, typically the last column where responses are recorded.
Once the trigger is configured, test it by submitting a new response in your Google Form. This will send data to Pabbly Connect for processing.
4. Sending WhatsApp Messages via Pabbly Connect
After setting up the trigger, it’s time to add an action step. Click on ‘Add New Action Step’ and select ‘WhatsApp Cloud API’ to send messages to leads. using Pabbly Connect
Choose the action event ‘Send Template Message’. Connect your WhatsApp account by entering the required details like token and phone number ID. Map the phone number field from Google Forms to ensure personalized messages are sent.
After configuring the action step, click on ‘Save and Send Test Request’ to verify that the message is sent successfully to the designated WhatsApp number.
5. Testing Your Automation Workflow
Once everything is set up, it’s crucial to test your automation. Go back to your Google Form and fill it out with test data. Submit the form to trigger the automation.
Check your WhatsApp to confirm that the message has been received. The message should indicate that the inquiry has been received, personalized with the user’s name. This confirms that your Pabbly Connect automation is functioning correctly.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the process of sending WhatsApp messages when a new lead is captured via Google Forms. This powerful integration not only saves time but also enhances communication efficiency.
