Learn how to optimize abandoned cart recovery using ThriveCart and Klaviyo automation with Pabbly Connect in this detailed tutorial. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience.
1. Accessing Pabbly Connect for ThriveCart and Klaviyo Integration
To optimize abandoned cart recovery, first, access Pabbly Connect. This platform allows you to integrate ThriveCart and Klaviyo seamlessly. Begin by visiting the Pabbly Connect website and signing in or creating a new account.
Once logged in, you will be directed to the dashboard where you can see various applications. Click on the ‘Access Now’ button for Pabbly Connect to start setting up your automation workflow.
Next, create a new workflow in Pabbly Connect for abandoned cart recovery. Click on the ‘Create Workflow’ button, and you will be prompted to name your workflow. For this tutorial, name it ‘Recover Abandoned Carts in ThriveCart with Klaviyo’ and select the appropriate folder.
- In the workflow window, set the trigger application as ThriveCart.
- Choose the trigger event as ‘Cart Abandoned’.
This setup allows Pabbly Connect to monitor your ThriveCart account for any abandoned carts, initiating the workflow automatically.
3. Connecting ThriveCart to Pabbly Connect
After setting up the trigger, connect your ThriveCart account to Pabbly Connect. When prompted, select ‘Add New Connection’ and enter your ThriveCart API key. You can find this key in your ThriveCart account settings under the API and Webhooks section.
Once you paste the API key in Pabbly Connect, click on ‘Save’. This establishes a connection, allowing Pabbly Connect to receive data from ThriveCart whenever a cart is abandoned.
4. Setting Up Klaviyo Automation with Pabbly Connect
Now, add an action step to your workflow by selecting Klaviyo as the action application in Pabbly Connect. Choose the action event as ‘Create/Update Profile’ to ensure that a new profile is created in Klaviyo whenever a cart is abandoned.
- Click on ‘Connect’ and select your existing Klaviyo connection.
- Map the email address, first name, and last name from the ThriveCart trigger data.
By mapping these fields, Pabbly Connect dynamically updates the Klaviyo profile with the data from the abandoned cart, allowing for targeted email campaigns.
5. Adding Profiles to a Klaviyo List via Pabbly Connect
Finally, add another action step in Pabbly Connect to include the newly created profile in a specific Klaviyo list. Select Klaviyo again and choose the ‘Add Profiles to List’ action event. Connect to your Klaviyo account if not already done.
Map the profile ID from the previous step to ensure the new profile is added to the designated list in Klaviyo. Click on ‘Save and Send Test Request’ to verify the action. If successful, the profile will be added to your specified list in Klaviyo, completing the workflow.
In summary, using Pabbly Connect to integrate ThriveCart with Klaviyo allows for efficient abandoned cart recovery. This process not only automates profile creation but also enables targeted marketing campaigns, enhancing your sales potential.
