Learn how to integrate Webflow with Active Campaign and Go High Level using Pabbly Connect for seamless automation. Step-by-step tutorial included! Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start integrating Webflow with Active Campaign and Go High Level, first access Pabbly Connect. This powerful automation platform allows you to connect various applications seamlessly. Visit Pabbly Connect’s website, and if you’re a new user, click on ‘Sign Up Free’ to create an account.
After signing up, log in to your Pabbly Connect account. Once logged in, you’ll see the dashboard where all your applications are listed. To create a new workflow, click on the ‘Create Workflow’ button in the top right corner. This is where you will set up your automation process.
In the workflow creation dialog, name your workflow something descriptive, like ‘Create Active Campaign and Go High Level Contact on Webflow Form Submission’. Select a folder to organize your workflows; you can create multiple folders as needed. This step is crucial for keeping your integrations tidy. using Pabbly Connect
After naming your workflow, click the ‘Create’ button. You will be directed to a new page where you can set up the trigger and action for your automation. In this case, the trigger will be a new form submission from Webflow. Select Webflow as your trigger application and choose the trigger event as ‘New Form Submission’.
- Click on the ‘New Form Submission’ option.
- Copy the Webhook URL provided by Pabbly Connect.
- Set up the Webhook in your Webflow account under the settings for your site.
After configuring the Webhook, publish your changes in Webflow. This ensures that any new form submissions will trigger the Pabbly Connect automation.
Setting Up Webflow Integration in Pabbly Connect
To connect Webflow with Pabbly Connect, you need to create a new Webhook. In your Webflow account, navigate to the settings of your site and select the ‘Apps and Integrations’ section. Scroll down to find the Webhooks option and click on the ‘Add Webhook’ button.
In the dialog that appears, choose ‘Form Submission’ as the trigger type. Paste the Webhook URL you copied from Pabbly Connect into the appropriate field. Select API version as API V1 and click on ‘Add Webhook’. Once done, publish the site to ensure the Webhook is active.
- Return to Pabbly Connect and test the Webhook by submitting a test form.
- Check Pabbly Connect for the response to confirm the connection.
Once you receive a response in Pabbly Connect, your Webflow integration is successfully set up and ready for action.
Adding Active Campaign Integration in Pabbly Connect
Next, it’s time to set up the action step in your workflow. In the Pabbly Connect dashboard, select Active Campaign as your action application. Choose the action event as ‘Create a Contact’. This action will automatically create a new contact in your Active Campaign account whenever a new form submission is received from Webflow.
To connect Active Campaign with Pabbly Connect, you need to enter your API key and URL. Go to your Active Campaign account, find the API settings, and copy the necessary credentials. Paste these into Pabbly Connect and click on ‘Save’ to establish the connection.
Map the fields from your Webflow form to the corresponding fields in Active Campaign. Ensure you map the email, first name, last name, and phone number.
After mapping the fields, click on ‘Save and Send Test Request’ to confirm that the integration works correctly. You should see a successful response indicating that the contact was created in Active Campaign.
Integrating Go High Level Using Pabbly Connect
Finally, you will set up the integration with Go High Level. In Pabbly Connect, add another action step and select ‘Lead Connector V2’ as the application. Choose the action event as ‘Create a Contact’. This ensures that every form submission from Webflow also creates a contact in your Go High Level account. using Pabbly Connect
To establish the connection, click on ‘Connect’ and select ‘Add New Connection’. You will need to choose the sub-account you’ve created in Go High Level. After selecting the sub-account, you will be prompted to map the required fields just like you did for Active Campaign.
Map the first name, last name, email, and phone number fields. Leave any non-required fields blank.
Once you have mapped all necessary fields, click on ‘Save and Send Test Request’ to finalize the integration. A successful response will confirm that the contact has been created in Go High Level.
In this tutorial, we demonstrated how to use Pabbly Connect to integrate Webflow with Active Campaign and Go High Level. By following these steps, you can automate the process of creating contacts in both applications whenever a new form submission occurs. This integration streamlines your workflow and enhances your lead management process.
