Learn how to integrate Unbounce and Flowdesk using Pabbly Connect for seamless lead management. Follow our detailed tutorial for automation. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To start integrating Unbounce and Flowdesk, you will first need to access Pabbly Connect. Sign in to your Pabbly account and navigate to the dashboard. From here, you can create a new workflow that will automate the process of adding new leads from Unbounce to Flowdesk.
Once logged in, look for the big blue button labeled ‘Create Workflow.’ Click this button to begin your automation setup. You will be prompted to name your workflow; for this tutorial, let’s name it ‘Add New Leads from Unbounce to Flowdesk as Subscribers.’ After naming your workflow, click ‘Create’ to proceed.
In Pabbly Connect, the trigger will be set as ‘New Form Submission’ from Unbounce. This means that every time a form is submitted on your Unbounce landing page, it will trigger the workflow you created. Select Unbounce as the trigger application and choose the trigger event. using Pabbly Connect
- Select Unbounce as your application.
- Choose the trigger event ‘New Form Submission’.
After copying the webhook URL, you need to integrate it into your Unbounce form. Go to your Unbounce dashboard, select the form you are working with, and navigate to the Integrations section. Here, you will add the webhook URL you copied to enable data transfer between Unbounce and Pabbly Connect.
3. Data Submission and Response Handling
Once the webhook is added to your Unbounce form, it’s time to test the integration. Submit a sample form on your Unbounce landing page with relevant details such as first name, last name, email, and contact number. After submission, Pabbly Connect will wait for the webhook response. using Pabbly Connect
- Enter details like first name, last name, email, and contact number in the form.
- Click on submit to send the data.
- Check Pabbly Connect for the received response.
Upon successful submission, you will see the data captured in Pabbly Connect, including the form name and all the details filled in the form. This confirms that the integration is working correctly and that Pabbly Connect is successfully receiving data from Unbounce.
Now that the trigger is set, the next step is to configure the action that will occur in Flowdesk. In the action module of Pabbly Connect, select Flowdesk as the application and choose the action event to create or update a subscriber.
To connect Flowdesk with Pabbly Connect, click on ‘Connect’ and authenticate your Flowdesk account. Enter your credentials and allow Pabbly Connect to access your Flowdesk account. Once connected, you will need to map the fields from the Unbounce form to the corresponding fields in Flowdesk to create a new subscriber.
After mapping the fields, click ‘Save and Send Test Request’ to finalize the integration. This will send the captured data from the Unbounce form to Flowdesk, creating a new subscriber. You should see a confirmation message indicating that the subscriber has been successfully created.
To verify, log into your Flowdesk account and check the audience section. You should see the new subscriber listed with the details you submitted. This confirms that your integration between Unbounce and Flowdesk via Pabbly Connect is successful and operational.
Now every time a new form is submitted on your Unbounce landing page, a new subscriber will automatically be created in Flowdesk, streamlining your lead management process.
In conclusion, integrating Unbounce and Flowdesk using Pabbly Connect allows for seamless lead management by automating the process of adding subscribers. This tutorial covered the steps to set up the integration, ensuring that every new form submission is captured and processed efficiently.
