Learn how to enroll TagMango users automatically on Typeform submission using Pabbly Connect. Follow this detailed tutorial for seamless integration. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To begin our integration process, we need to access Pabbly Connect. This platform allows seamless automation between various applications, including Typeform and TagMango.
Visit the Pabbly Connect homepage by entering the URL in your browser. If you are an existing user, click on the ‘Sign In’ button. For new users, select ‘Sign Up Free’ to create an account and receive 300 free tasks to explore the software.
The next step involves creating a workflow in Pabbly Connect. After signing in, navigate to the dashboard and click on the ‘Create Workflow’ button located at the top right corner.
- Name your workflow as ‘Enroll TagMango User on Typeform Submission’.
- Select a folder to save your workflow. You can create a new folder if needed.
After creating the workflow, you will see the main automation principles: trigger and action. Here, the trigger will be Typeform, and the action will be TagMango.
3. Setting Up the Trigger with Typeform
In this section, we will set up the trigger in Pabbly Connect using Typeform. Select Typeform as your trigger application and choose the trigger event as ‘New Entry’. This ensures that every time a new form submission is received, Pabbly Connect captures the response.
Next, click on ‘Connect’ to link your Typeform account with Pabbly Connect. If prompted, grant access to ensure that Pabbly Connect can retrieve your Typeform data. Once connected, select the specific form from the dropdown menu that you want to use for this automation.
4. Mapping Data to TagMango
After setting up the trigger, the next step is to connect TagMango as the action application in Pabbly Connect. Select TagMango and choose the action event as ‘Migrate User’. This action will automatically enroll users who submit the Typeform.
To connect TagMango, you will need to enter your API key. Log into your TagMango account, navigate to the automations section, and copy your API key. Return to Pabbly Connect, paste the API key, and proceed to map the user data from Typeform to TagMango.
- Map the first name and last name fields from Typeform to TagMango.
- Also map the email address and phone number fields accordingly.
After mapping the necessary fields, click on ‘Save and Send Test Request’ to ensure the setup works correctly. You should receive a successful response indicating that the user has been enrolled in TagMango.
5. Testing the Integration
To finalize the integration process in Pabbly Connect, perform a test submission on your Typeform. Enter dummy data for the required fields and submit the form.
Once the submission is complete, return to Pabbly Connect to check the response. You should see the details of the new user, confirming that they have been successfully enrolled in your TagMango account. This automated process streamlines user enrollment and enhances efficiency.
In this tutorial, we demonstrated how to automate the enrollment of TagMango users through Typeform submissions using Pabbly Connect. By following the steps outlined, you can ensure a seamless integration that saves time and improves user experience.
