Learn how to automate your Tidal bookings by integrating with Moen using Pabbly Connect. Follow this detailed tutorial for seamless automation. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To start the integration process, you need to access Pabbly Connect. Open your browser and type in the URL Pabbly.com/connect. Here, you will find options to sign in or sign up for a free account.
If you’re a new user, click on the ‘Sign Up for Free’ button to create your account. After signing up, you will receive 100 free tasks monthly to explore the features of Pabbly Connect. Once registered, log in to your account to access the dashboard.
After logging into Pabbly Connect, you can create a new workflow by clicking on the ‘Create Workflow’ option in the top right corner. A dialog box will appear asking for a name for your workflow. For this integration, name it ‘Create Moen Subscriber for Tidal Booking Automatically’.
- Select the folder where you want to save the workflow.
Now, you will see two windows open for Trigger and Action. The Trigger is the event that starts the workflow, while the Action is what happens in response. Here, we will set Tidal as the Trigger application and Moen as the Action application.
3. Setting Up the Trigger with Tidal
In this step, you will configure Tidal as the Trigger in Pabbly Connect. Select Tidal as your Trigger application and choose ‘New Booking’ as the Trigger event. This means that whenever a new booking is made in Tidal, it will trigger the workflow.
Next, click on ‘Connect’ and then select ‘Add New Connection’ to link your Tidal account. Once the connection is successful, Pabbly Connect will check for new data every 10 minutes. After setting this up, click on ‘Save and Send Test Request’ to capture the latest booking details from Tidal.
4. Setting Up the Action with Moen
Now that the Trigger is set, you need to configure Moen as the Action application in Pabbly Connect. Select Moen and choose the action event ‘Add New Subscriber’. Click on ‘Connect’ and add a new connection to your Moen account using the API key.
To find your API key, go to your Moen account settings and copy the API key from there. Paste it in the Pabbly Connect interface. After establishing the connection, you will need to fill in the subscriber details using the data captured from the Tidal booking.
- Select the mailing list where you want to add the subscriber.
- Map the name and email fields from the Tidal booking response.
Click on ‘Save and Send Test Request’ to finalize the integration. You will receive a response confirming that the subscriber has been added to Moen.
5. Verifying the Integration
To ensure everything is working correctly, check your Moen account under the audience section to see if the new subscriber has been added. Navigate to the email list you selected earlier and view all members to find the details of the newly added subscriber.
This confirms that your workflow is functioning correctly. Whenever a new booking is made in Tidal, the corresponding subscriber will be added automatically to Moen through Pabbly Connect. This automation saves time and ensures that your email marketing lists are always updated.
In this tutorial, we explored how to integrate Tidal bookings with Moen using Pabbly Connect. By following the steps outlined, you can automate the process of adding new subscribers effortlessly. This integration enhances your workflow efficiency and ensures seamless communication with your clients.
