Learn how to integrate Thrive Card with Thrive Using Pabbly Connect. This detailed tutorial covers API keys, workflows, and automation steps for seamless integration. Navigate the automation landscape confidently with clear, structured guidance suitable for professionals regardless of prior technical experience. with Pabbly Connect.
1. Setting Up the Workflow in Make for Thrive Card
To begin integrating Thrive Card with Thrive Using Pabbly Connect, you must first set up the workflow. Start by logging into your Make account and clicking on the ‘Create Workflow’ button. Name your workflow appropriately, such as ‘Create Member for User on Thrive Card Purchase’.
Next, once the workflow page loads, you will see the basic building blocks, which include triggers and actions. The trigger is the event that initiates the workflow, which in this case is a purchase made through Thrive Card. The action will involve creating a user in Thrive based on that purchase.
2. Selecting the Trigger Application: Thrive Card
In this step, you need to select the trigger application for your workflow. Click on the trigger window and choose Thrive Card as your application. The trigger event you want to select is ‘Product Purchase’. This will ensure that every time a purchase is made on Thrive Card, the workflow is activated.
- Select ‘Add New Connection’ to connect to Thrive Card.
- You will need to provide your API key from Thrive Card.
- Obtain the API key from the API and Webhooks section in your Thrive Card account settings.
Once you have entered the API key, click on ‘Save’ to establish the connection. After connecting, select the product you are selling and set its status. For example, you might choose the ‘PHP Language Course’ as your product.
3. Performing a Test Purchase on Thrive Card
Now that your trigger is set up, it’s time to perform a test purchase to ensure everything works as expected. Navigate to the checkout link of your product and fill in the customer details using test data. Make sure to select the product and set it to test mode. using Pabbly Connect
After filling in the customer information, use the test card details provided by Thrive Card to complete the purchase. Once the order is processed, you should see the response captured in your workflow. This response will include details such as the unit price, payment processor, and customer information.
4. Adding User to Thrive Using Member Vault
With the test purchase completed, the next step is to add the user to Thrive using Member Vault. For this, search for the Member Vault application in your workflow and select the action event as ‘Add User’. Click on ‘Connect’ and add a new connection by providing the API key and subdomain name from your Member Vault account. using Pabbly Connect
- Copy your subdomain from the URL of your Member Vault account.
- Obtain the API key from the Integrations section in Member Vault.
- Paste both the subdomain and API key into the respective fields in Make.
Once connected, map the email address, first name, last name, and course from the previous step’s response. This ensures that the user information is accurately transferred to Member Vault.
5. Testing and Activating Your Workflow
After mapping all necessary fields, it’s time to test the connection with Member Vault. Click on the ‘Save and Send Test Request’ button. If successful, you should see a new user added to your Member Vault account.
Check the user section in Member Vault to confirm that the new user appears with the correct details. Once verified, your workflow is complete. You only need to set it up once, and it will automatically trigger every time a real purchase occurs on Thrive Card.
In conclusion, integrating Thrive Card with Thrive Using Pabbly Connect is a straightforward process that automates user creation based on purchases. This saves time and ensures a seamless experience for your customers. Follow the steps outlined above for a successful integration, and enjoy the benefits of automation in your business.
