Learn how to integrate Teamleader CRM with Telegram using Pabbly Connect to notify your team about new contacts. Step-by-step tutorial included. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start integrating Teamleader CRM with Telegram, you need to access Pabbly Connect. Begin by visiting the Pabbly website and navigating to the Connect section.
Type ‘Pabbly.com/connect’ in your browser’s address bar. You will be redirected to a page where you can either sign in or sign up for a free account, which includes 100 free tasks monthly. Signing up is straightforward and allows you to begin automating your workflows.
After signing in to Pabbly Connect, you will find the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button and name your workflow, such as ‘Teamleader to Telegram Notification’.
  • Select ‘Teamleader’ as the Trigger Application.
  • Choose ‘New Contact’ as the Trigger Event.
  • Connect your Teamleader account by following the prompts.
Once you have set up the trigger, proceed to test it by adding a new contact in Teamleader CRM. This step ensures that the connection between Teamleader and Pabbly Connect is functioning correctly.
3. Setting Up Telegram Notifications
Now, it’s time to configure the action step to send notifications to Telegram. In Pabbly Connect, select ‘Telegram’ as the Action Application and choose ‘Send Message’ as the Action Event.
  • Connect your Telegram account using the bot token from BotFather.
  • Create a new group in Telegram and add the bot as a member.
  • Ensure the bot is an admin in the group for message sending permissions.
After configuring the connection, map the fields from Teamleader to the Telegram message format. This ensures that when a new contact is added, the relevant details are sent to your team via Telegram.
4. Testing the Integration
With everything set up, it’s time to test the integration. In Pabbly Connect, click ‘Save and Send Test Request’ to trigger the workflow. This will send a message to your Telegram group with the details of the new contact added in Teamleader.
To verify the results, check your Telegram group for the message. You should see a notification like ‘Hello team, we have a new contact in our Teamleader CRM’ followed by the contact’s details. If the message is received, the integration is successful!
5. Finalizing Your Workflow in Pabbly Connect
Once the test is successful, you can finalize your workflow in Pabbly Connect. Make sure to save all your settings, and you can choose to add more actions if needed.
This integration allows your team to stay updated in real-time about new contacts in Teamleader CRM, enhancing communication and efficiency. You can now explore more features of Pabbly Connect to further automate your workflows.
Integrating Teamleader CRM with Telegram using Pabbly Connect streamlines your team’s communication regarding new contacts. By following the steps outlined, you can ensure that your team is always informed and ready to act on new leads. Automation like this can significantly enhance productivity and collaboration within your organization.
