Learn how to seamlessly integrate Tag Mango leads with MailChimp using Pabbly Connect in this step-by-step tutorial. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To start integrating Tag Mango leads with MailChimp, you first need to access Pabbly Connect. Open your browser and navigate to the Pabbly Connect landing page.
If you are new to Pabbly Connect, click on the ‘Sign Up Free’ button to create an account. If you already have an account, simply click ‘Sign In’. After logging in, click on ‘Access Now’ under Pabbly Connect to reach the dashboard.
Once in the Pabbly Connect dashboard, you will need to create a new workflow to automate the integration. Click on the ‘Create Workflow’ button and name your workflow, for example, ‘Tag Mango to MailChimp’. Select the appropriate folder for your workflow and click ‘Create’. using Pabbly Connect
The workflow interface will show two main windows: the trigger and action windows. The trigger window is for setting up what event will start the workflow, while the action window is for what happens next. In this case, the trigger will capture leads from Tag Mango.
Setting Up the Trigger with Tag Mango
In the trigger window, select Tag Mango as the app. For the trigger event, choose ‘Lead Capture’. Click on ‘Connect’ and select ‘Add New Connection’. You will need to enter the API key from your Tag Mango account, which you can find under the ‘Platform Integrations’ section. using Pabbly Connect
After entering the API key, select the specific page from which you want to capture leads. For example, you can choose the ‘Introduction to Generative AI’ page. Click ‘Save and Send Test Request’ to confirm the connection. Pabbly Connect will wait for a response from Tag Mango, indicating that the trigger is set up correctly.
Adding MailChimp as an Action in Pabbly Connect
Next, you will add MailChimp as the action app in your workflow. In the action window, search for MailChimp and select it. Choose the action event ‘Add New Member with Custom Fields’. Click ‘Connect’ and enter your MailChimp API key and data center. using Pabbly Connect
To get your API key, log into your MailChimp account, navigate to the profile section, then to ‘Extras’ and ‘API Keys’. Generate a new API key, name it, and copy it to paste into Pabbly Connect. For the data center, check your MailChimp URL for the identifier (e.g., us6) and enter it in Pabbly Connect.
- Log into MailChimp and navigate to the profile section.
- Go to ‘Extras’ and select ‘API Keys’.
- Generate a new API key and copy it for Pabbly Connect.
After entering the API token and data center, click ‘Save’. Now, map the fields from Tag Mango to MailChimp, including the email address, name, and company details.
Testing the Automation Workflow
After mapping all necessary fields, it’s time to test your automation. Make a dummy lead submission on your Tag Mango page. For instance, enter a name, email, and company information, then submit the form.
Once the form is submitted, check Pabbly Connect to see if the lead details have been captured correctly. You should see the new lead information in the Pabbly Connect dashboard. Next, verify in your MailChimp account that the new lead has been added as a subscriber with the correct details.
This testing phase confirms that your automation is functioning as intended. If everything is set up correctly, you will see the same lead details reflected in MailChimp, showcasing the seamless integration powered by Pabbly Connect.
This tutorial demonstrates how to integrate Tag Mango leads with MailChimp using Pabbly Connect. By following these steps, you can automate the process of adding new leads as subscribers in MailChimp, enhancing your marketing efforts efficiently.
