Learn how to automate SuiteDash contacts creation from AWeber subscribers using Pabbly Connect. Follow this detailed tutorial for seamless integration. This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To create SuiteDash contacts when AWeber subscribers are created, you need to access Pabbly Connect. Start by signing into your Pabbly account and navigating to the Pabbly Connect dashboard.
Once you’re on the dashboard, locate the big blue button labeled ‘Create Workflow’. This is where you will begin setting up your automation to connect AWeber and SuiteDash.
After clicking on ‘Create Workflow’, give your workflow a name, such as ‘Create SuiteDash Contacts When AWeber Subscribers Are Added’. This helps you identify the workflow later. Click on ‘Create’ to proceed. using Pabbly Connect
- Select AWeber as your trigger application.
- Choose ‘New Subscriber in List’ as the trigger event.
- Connect your AWeber account to Pabbly Connect by clicking ‘Connect’.
After connecting, select the specific list from AWeber where new subscribers will be added. This is crucial for the workflow to function correctly.
3. Setting Up the Trigger in AWeber
In this step, you will configure the trigger settings. Select the list ID from the dropdown that corresponds to your AWeber account. After choosing the list, click on ‘Save and Send Test Request’ to fetch the data of the newly created subscriber. using Pabbly Connect
Make sure to add a new subscriber in AWeber before testing. This is essential as it allows Pabbly Connect to retrieve the correct data for the workflow.
- Enter the subscriber’s name, email, and any other required fields.
- Click ‘Add Subscriber’ to create the subscriber in AWeber.
- Return to Pabbly Connect and click ‘Save and Send Test Request’ again.
This will ensure that the newly added subscriber’s details are sent to Pabbly Connect for the next steps.
4. Creating a Contact in SuiteDash
Now that you have set up the trigger, it’s time to create a contact in SuiteDash. Choose SuiteDash as your action application and select ‘Create Contact’ as the action event. using Pabbly Connect
Connect your SuiteDash account to Pabbly Connect by entering your Pabbly ID and secret key. You can find these in your SuiteDash account under My Account > Integrations > Secure API.
Map the fields from AWeber to SuiteDash, including first name, last name, and email address. Use the text formatter to split the full name into first and last names. Click ‘Save and Send Test Request’ to finalize the contact creation.
Confirm that the contact has been successfully created in SuiteDash by checking your CRM for the new entry.
After successfully mapping the necessary fields and testing the action step, it’s crucial to ensure everything works as intended. Go back to your SuiteDash account and verify that the new contact appears with the correct details.
If the contact was created successfully, you will see a success message in Pabbly Connect. This indicates that your integration between AWeber and SuiteDash is functioning correctly through Pabbly Connect.
In case of any errors, revisit your workflow to troubleshoot and correct the mappings or connections. Always ensure that the data being sent from AWeber matches the required fields in SuiteDash.
In this tutorial, we demonstrated how to automate the creation of SuiteDash contacts from AWeber subscribers using Pabbly Connect. This integration simplifies managing contacts and enhances your workflow efficiency.
