Learn how to enroll Thinkific users automatically through Razorpay payments using Pabbly Connect. Follow our detailed tutorial for seamless integration. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To integrate Razorpay with Thinkific, you’ll first need to access Pabbly Connect. Start by visiting the Pabbly Connect website and signing in to your account. If you are new, you can sign up for free and get started with 100 tasks monthly.
Once logged in, navigate to the Pabbly Connect dashboard. Here, you will see all your workflows. Click on the ‘Create New Workflow’ button to begin setting up your Razorpay and Thinkific integration.
2. Setting Up Razorpay as a Trigger Application
In this step, you will configure Razorpay as the trigger application in Pabbly Connect. Select Razorpay from the list of applications and choose the trigger event as ‘Payment Captured’. This event will trigger the workflow whenever a payment is successfully processed.
- Select Razorpay as the trigger application.
- Choose ‘Payment Captured’ as the trigger event.
- Connect your Razorpay account by entering the required API credentials.
After setting up the trigger, click on ‘Save and Send Test Request’ to verify the connection. This step ensures that Pabbly Connect can successfully capture payment data from Razorpay.
3. Configuring Thinkific as the Action Application
Next, you will set up Thinkific as the action application in your Pabbly Connect workflow. Select Thinkific and choose the action event as ‘Create User’. This action will automatically enroll users in your course once a payment is confirmed.
To connect Thinkific, you need to provide your Thinkific subdomain and API key. After entering these details, you can map the fields from the Razorpay payment data to the user creation fields in Thinkific.
- Enter your Thinkific subdomain.
- Provide the API key from your Thinkific account.
- Map the user details from Razorpay to Thinkific fields.
Once all details are mapped, click ‘Save and Send Test Request’. This will create a test user in Thinkific, confirming your integration is working correctly via Pabbly Connect.
4. Finalizing the Integration and Testing
After successfully testing the connection between Razorpay and Thinkific through Pabbly Connect, you can finalize your integration. Ensure that all user data is correctly mapped and that the correct course is selected for enrollment.
To test the entire workflow, perform a test payment through Razorpay. This will trigger the workflow and create a user in Thinkific automatically. Check your Thinkific account to confirm that the user has been enrolled in the specified course.
It’s essential to monitor the integration after the initial setup to ensure everything functions as intended. Any issues can be resolved through the Pabbly support channels.
5. Conclusion: Seamless Integration with Pabbly Connect
Integrating Razorpay with Thinkific using Pabbly Connect streamlines the enrollment process for your online courses. By automating user enrollment upon successful payment, you save time and reduce manual errors.
With this tutorial, you can efficiently set up the integration and ensure that your users are automatically enrolled in Thinkific after making payments via Razorpay. Enjoy the benefits of automation with Pabbly Connect!
