Learn how to integrate PayKickstart with Twilio using Pabbly Connect to automate SMS notifications for new sales. Follow our detailed tutorial for seamless setup! Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
To integrate PayKickstart with Twilio, you need to start with Pabbly Connect. First, open your browser and type in the Pabbly website URL. Once there, navigate to the ‘Products’ section and select ‘Connect’. Sign in to your account or create a new one if you haven’t already.
After logging in, you will be directed to the Pabbly Connect dashboard. Here, you can create a new workflow that will automate sending SMS notifications from Twilio whenever a new sale is made in PayKickstart. This integration simplifies the process without requiring any coding skills.
In Pabbly Connect, creating a workflow is essential for the integration process. Click on the ‘Create Workflow’ button located at the top right corner of your dashboard. You will be prompted to name your workflow; you can name it something like ‘PayKickstart to Twilio’. After naming it, hit the ‘Create’ button. using Pabbly Connect
- Select ‘PayKickstart’ as the trigger app.
- Choose ‘Transaction Sale’ as the trigger event.
- Click ‘Save’ to proceed.
Once you save the trigger, Pabbly Connect will wait for a new sale to occur in your PayKickstart account, which will initiate the workflow. This setup enables real-time data transfer between PayKickstart and Twilio.
3. Setting Up PayKickstart for Integration
Next, you need to configure PayKickstart to send data to Pabbly Connect. Log into your PayKickstart account and navigate to the ‘Campaigns’ section. Select the product you wish to integrate and click on the ‘Edit’ button.
Scroll down to the ‘Integrations’ section and look for the ‘IPN URL’. Here, you will paste the webhook URL provided by Pabbly Connect. After pasting the URL, set the event to ‘Transaction Sale’ and click ‘Save’. This step ensures that every new sale triggers the webhook, sending data to Pabbly Connect.
4. Capturing the Webhook Response in Pabbly Connect
After configuring PayKickstart, go back to Pabbly Connect and click on the ‘Capture Webhook Response’ button. This action allows Pabbly Connect to listen for incoming data from PayKickstart. To test this, create a dummy sale in your PayKickstart account.
- Fill in the customer details, including name and email.
- Ensure you provide a valid phone number.
- Complete the purchase to trigger the webhook.
Once the dummy sale is completed, return to Pabbly Connect, where you should see the captured data from the sale, confirming that the integration is working correctly.
5. Sending SMS Notifications via Twilio
Now that you have captured the webhook response, the final step is to send SMS notifications through Twilio. Add a new action in Pabbly Connect and select ‘Twilio’ as the action app. Choose ‘Send SMS’ as the action event. using Pabbly Connect
Fill in the required fields, including your Twilio Account SID and Authorization Token. These credentials can be found in your Twilio account settings. After entering the details, compose your SMS message using the data captured from PayKickstart, like the customer’s name and product details. Finally, click ‘Save and Send Test Request’ to verify that the SMS is sent successfully.
Integrating PayKickstart with Twilio using Pabbly Connect allows you to automate SMS notifications for new sales effectively. This setup enhances customer communication and ensures timely updates. Follow these steps to streamline your sales process and improve customer engagement.
