Learn how to integrate Mailchimp with Wix Forms using Pabbly Connect. This step-by-step guide will help you automate your email marketing process seamlessly. Master proven automation processes with practical implementation examples and strategic recommendations you can apply immediately in your workflow.
To start integrating Wix Forms with Mailchimp, you first need to access Pabbly Connect. This platform serves as the bridge between the two applications, allowing seamless data transfer.
Once you’re on the Pabbly Connect dashboard, you can either log in if you are an existing user or sign up if you are new. Upon creating your account, you will receive 100 free tasks to get started. After logging in, look for the ‘Create Workflow’ button on the right side of the dashboard.
After clicking ‘Create Workflow’, you will need to name your workflow. For this integration, you might name it something like ‘Mailchimp Subscriber from Wix Form Submission’. This name should reflect the purpose of your integration. using Pabbly Connect
- Click ‘Create’ to proceed.
- Select ‘Wix Forms’ as your trigger application.
Once you have selected these options, Pabbly Connect will generate a webhook URL. This URL is crucial as it will connect your Wix Forms to Pabbly Connect. Copy this webhook URL for the next steps.
3. Setting Up Wix Automation
Next, you’ll need to set up your Wix account to send data to the webhook URL generated by Pabbly Connect. Go to your Wix dashboard and navigate to the ‘Automation’ section.
Create a new automation by clicking ‘New Automation’. Name this automation, for example, ‘Mailchimp Integration’. Choose ‘Form Submitted’ as the trigger type and select the specific form that you want to use for this integration.
- Set the action to ‘Send via Webhook’.
- Paste the webhook URL you copied from Pabbly Connect.
- Ensure the request type is set to POST.
Once you’ve completed these steps, activate the automation. This setup allows your Wix Forms to send data directly to Pabbly Connect whenever a form is submitted.
Now that your Wix Forms are set up to communicate with Pabbly Connect, it’s time to test the integration. Go back to your Wix Forms and submit a test entry to see if the data is captured correctly.
After submitting the form, return to the Pabbly Connect dashboard. You should see the response from your form submission displayed in the webhook response section. This confirms that the data is being received correctly.
Now, you will set up the action to add the new subscriber to Mailchimp. Choose Mailchimp as your action application and select ‘Add New Member with Custom Fields’ as the action event. Connect your Mailchimp account by providing the necessary API key and data center information.
5. Finalizing the Integration with Pabbly Connect
After successfully connecting to Mailchimp, you need to map the fields from your Wix form submission to Mailchimp. This includes the subscriber’s email, first name, and last name. Mapping ensures that the correct data is sent to Mailchimp every time a form is submitted.
Once you have mapped the fields, click on ‘Save and Send Test Request’ to finalize the integration. If everything is set up correctly, you should see the new subscriber added to your Mailchimp audience list.
This entire process showcases how Pabbly Connect streamlines the integration between Wix Forms and Mailchimp, automating the subscriber addition process efficiently.
In this tutorial, we explored how to integrate Mailchimp with Wix Forms using Pabbly Connect. By following these steps, you can automate your email marketing and ensure new leads are added as subscribers effortlessly.
