Learn how to automate the process of adding new Kit subscriber details to Google Sheets using Pabbly Connect. Follow our detailed tutorial for seamless integration.
To start integrating Kit with Google Sheets, you first need to access Pabbly Connect. This platform allows you to automate various tasks seamlessly.
Visit the Pabbly Connect website and sign in to your account. If you are a new user, you can sign up for free and get 100 free tasks every month. After logging in, you will see the dashboard where all your applications are displayed.
Creating a workflow is essential for automating the process. In Pabbly Connect, click on the ‘Create Workflow’ button located in the top right corner of your dashboard.
- Give your workflow a name, such as ‘Add New Kit Subscriber Details to Google Sheets’.
- Select a folder to save your workflow, like ‘Google Sheets Automations’.
- Click on the ‘Create’ button to finalize your workflow.
Once the workflow is created, you will see two sections labeled ‘Trigger’ and ‘Action’. The trigger is what starts the automation process, and the action is what happens as a result.
3. Setting Up the Trigger for Kit
The next step involves setting up the trigger in Pabbly Connect. Select Kit as your trigger application. This will allow Pabbly Connect to monitor for new subscribers.
For the trigger event, choose ‘New Subscriber’. This means that whenever a new subscriber is added to your Kit account, Pabbly Connect will capture this information. Click on the ‘Connect’ button to proceed.
- If you haven’t connected Kit yet, click on ‘Add New Connection’.
- Enter your API Key and API Secret from your Kit account to authorize the connection.
Once connected, you can test the trigger by adding a new subscriber in your Kit account. This will ensure that the integration is working correctly.
4. Setting Up the Action to Google Sheets
Now that your trigger is set, it’s time to add the action step in Pabbly Connect. Select Google Sheets as the action application.
For the action event, choose ‘Add New Row’. This will allow Pabbly Connect to add subscriber details directly into your Google Sheets. Click on the ‘Connect’ button and authorize Pabbly Connect to access your Google Sheets.
Select the spreadsheet where you want to add the subscriber details. Map the fields such as Subscriber ID, First Name, Last Name, Email, Phone Number, and Status from the previous step.
Once you have mapped all the required fields, click on the ‘Save and Send Test Request’ button. This will create a new row in your Google Sheets with the subscriber’s information.
5. Testing the Integration
To ensure everything is functioning correctly, you should test the entire integration process using Pabbly Connect. Create a new subscriber in your Kit account using the form you previously set up.
After submitting the form, check your Google Sheets to verify that the new subscriber’s details have been added successfully. You should see the new entry with all the mapped information accurately displayed.
This confirms that the integration between Kit and Google Sheets has been successfully established using Pabbly Connect. You can now automate the addition of new subscribers effortlessly, saving time and minimizing errors.
In this tutorial, we demonstrated how to use Pabbly Connect to automate the integration between Kit and Google Sheets. By following the steps outlined, you can streamline your subscriber management process effectively.
