Learn how to integrate Kit Sequence with GoHighLevel using Pabbly Connect for seamless lead management. Follow this step-by-step tutorial for effective automation. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Accessing Pabbly Connect to Start Integration
To integrate Kit Sequence with GoHighLevel, the first step is to access Pabbly Connect. Begin by navigating to the Pabbly Connect website and signing in to your account. If you do not have an account, you can sign up for free, which includes 100 free tasks each month for new users.
Once signed in, you will arrive at the Pabbly Connect dashboard. Here, you can create a new workflow by clicking on the ‘Create Workflow’ button. This action initiates the process of integrating Kit Sequence and GoHighLevel through Pabbly Connect, allowing for seamless data transfer between the two applications.
2. Creating the Workflow in Pabbly Connect
After accessing Pabbly Connect, it’s time to create the integration workflow. Click on the ‘Create Workflow’ button and select the classic version of the workflow builder. Name your workflow something meaningful, such as ‘Add Leads to GoHighLevel CRM from Kit.’ This name helps identify the workflow’s purpose.
  • Choose Kit as the trigger application.
  • Set the trigger event to ‘New Subscriber’ to initiate the workflow.
  • Select GoHighLevel (Lead Connector) as the action application.
  • Set the action event to ‘Create Contact’ for adding new leads.
By following these steps, you ensure that the workflow is correctly set up to respond to new subscribers in Kit by creating corresponding contacts in GoHighLevel through Pabbly Connect.
3. Connecting Kit Sequence and GoHighLevel in Pabbly Connect
Next, you need to establish a connection between Kit and Pabbly Connect. Click on the ‘Connect’ button next to the Kit application and choose ‘Add New Connection.’ Enter your API key and API secret from your Kit account to authorize the connection.
To find your API credentials, log into your Kit account, navigate to the account settings, and locate the developer option. Copy the API key and secret, and paste them into Pabbly Connect. After saving the connection, click on the ‘Save and Send Test Request’ button to ensure everything is working properly.
4. Testing the Integration with a New Subscriber
Now that you have set up the connection, it’s time to test the integration. Go to your Kit account and add a new subscriber by clicking on the ‘Add Subscriber’ button. Fill in the subscriber’s name and email, then click on the ‘Finish’ button to complete the process.
After adding the subscriber, return to Pabbly Connect and check if the test request captured the new subscriber’s details. If successful, the subscriber’s information should appear in the response section, confirming that the trigger step is functioning correctly.
5. Finalizing the Automation in Pabbly Connect
With the test successfully completed, you can now finalize the action step to create a contact in GoHighLevel. Click on the ‘Connect’ button for the Lead Connector and select ‘Add New Connection.’ This will allow you to link your GoHighLevel account to Pabbly Connect.
Fill in the required fields using the mapping feature to dynamically link the subscriber’s first name and email to the contact fields in GoHighLevel. Once all fields are mapped, click on the ‘Save and Send Test Request’ button to create the contact. After refreshing your GoHighLevel account, you should see the new contact created with the same details as the subscriber added in Kit.
By following these steps, you can effectively integrate Kit Sequence with GoHighLevel using Pabbly Connect. This automation allows for efficient lead management by ensuring that every new subscriber added in Kit is automatically created as a contact in GoHighLevel. This seamless integration enhances your workflow and improves customer follow-up processes.
