Learn how to integrate Instamojo with Mailgun using Pabbly Connect. This detailed tutorial covers all steps to automate member creation on Mailgun for every sale on Instamojo.
To begin the integration between Instamojo and Mailgun using Pabbly Connect, first, navigate to the Pabbly Connect website. You can do this by typing ‘Pabbly.com/connect’ in your browser. Once there, sign in to your existing account, or create a new one if you are a first-time user.
After logging in, you will be directed to the Pabbly Connect dashboard. Here, you can manage your workflows and integrations. Click on the ‘Create Workflow’ button to initiate a new automation process, which will be essential for connecting Instamojo with Mailgun.
2. Setting Up the Trigger for Instamojo Sales
In this section, we will set up the trigger event in Pabbly Connect that will start the workflow whenever a new sale occurs on Instamojo. Select ‘Instamojo’ as the application and choose the ‘New Sale’ trigger event.
- Select ‘Instamojo’ as the trigger application.
- Choose ‘New Sale’ as the trigger event.
- Connect your Instamojo account using the provided webhook URL.
Once the connection is established, you will need to configure the webhook settings in your Instamojo account. This involves navigating to the settings of the product for which you want to capture sales and entering the webhook URL provided by Pabbly Connect. This setup ensures that every time a sale is made, it triggers the workflow.
3. Configuring the Webhook in Instamojo
To finalize the integration, you need to configure the webhook in your Instamojo account. Go to your product settings and find the ‘Webhook’ section. Paste the webhook URL from Pabbly Connect into the designated field.
- Access the product settings in Instamojo.
- Locate the ‘Webhook’ section.
- Paste the copied webhook URL from Pabbly Connect and save changes.
After saving, perform a test submission in Instamojo to ensure that the webhook is correctly configured. This will send a sample sale to Pabbly Connect, allowing you to verify that the data is being captured properly.
4. Creating a Mailgun Member from Instamojo Sales
With the trigger set up, the next step is to configure the action in Pabbly Connect that will create a member on Mailgun for each sale made on Instamojo. Select ‘Mailgun’ as the action application and choose the ‘Create Member’ action event.
You will need to provide details such as the email address and name of the member. Use the mapping feature in Pabbly Connect to pull information directly from the Instamojo sale data. This ensures that every new member created will have the correct information associated with them.
After setting up the action to create a Mailgun member, click on the ‘Save and Send Test Request’ button in Pabbly Connect. This will send a test request to Mailgun to create a member using the details mapped from the Instamojo sale.
Once the test is successful, you can check your Mailgun account to confirm that the new member has been created. This completes the integration process. Whenever a new sale occurs on Instamojo, Pabbly Connect will automatically create a corresponding member in Mailgun.
Integrating Instamojo with Mailgun using Pabbly Connect allows you to automate the creation of members based on sales. This setup enhances your business efficiency by ensuring that every sale is followed by immediate member creation in Mailgun, streamlining your workflow.
