Learn how to integrate HubSpot Forms with Shopify using Pabbly Connect. Create new Shopify customers from HubSpot form submissions effortlessly. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Accessing Pabbly Connect for HubSpot and Shopify Integration
To begin integrating HubSpot Forms with Shopify, you need to access Pabbly Connect. This powerful automation tool allows you to create workflows that connect different applications seamlessly.
First, log in to your Pabbly Connect account. If you do not have an account, you can easily create one for free. Once logged in, navigate to the dashboard where you can start creating your integration.
After accessing Pabbly Connect, the next step is to create a new workflow. Click on the ‘Create New Workflow’ button to begin the setup process.
- Name your workflow appropriately, for instance, ‘HubSpot to Shopify Integration’.
- Select ‘HubSpot’ as the trigger application.
After setting up the trigger, Pabbly Connect will prompt you to connect your HubSpot account. This involves providing the necessary API key from your HubSpot account to establish a secure connection.
3. Setting Up HubSpot Form for Customer Data Capture
In this step, you will need to ensure that your HubSpot form is correctly set up to capture customer data. Navigate to the HubSpot dashboard and create a new form if you haven’t done so already.
Make sure to include fields such as first name, last name, email address, and mobile number. These fields are crucial as they will be used to create new customers in Shopify through Pabbly Connect.
4. Integrating Shopify with Pabbly Connect
Now that your HubSpot form is ready, it’s time to integrate Shopify. Go back to your Pabbly Connect workflow and add an action step. Select ‘Shopify’ as the action application.
- Choose ‘Create Customer’ as the action event.
- Connect your Shopify account by entering the required store credentials.
- Map the fields from your HubSpot form to the corresponding fields in Shopify.
This mapping is essential for ensuring that the data captured from HubSpot is correctly entered into Shopify. Once you have completed this step, save your workflow.
5. Testing the Integration
Finally, it’s important to test your integration to ensure everything works smoothly. Submit a test form using your HubSpot form to see if it creates a new customer in Shopify.
Check your Shopify account to verify that the new customer appears as expected. If you encounter any issues, revisit your Pabbly Connect workflow to troubleshoot the mapping and connections.
Integrating HubSpot Forms with Shopify using Pabbly Connect allows you to automate customer creation effortlessly. By following the steps outlined in this tutorial, you can ensure that new customer data from HubSpot forms is seamlessly transferred to your Shopify store, enhancing your business efficiency.
