Learn how to seamlessly integrate Graphy subscribers with HubSpot using Pabbly Connect. Follow this step-by-step guide for a smooth setup. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To integrate Graphy subscribers with HubSpot, you will first need to access Pabbly Connect. Begin by navigating to the Pabbly Connect website. If you are a new user, click on the ‘Sign Up for Free’ button, which allows you to create an account quickly and receive 100 free tasks.
Once signed up, log in to your account. After logging in, you will be directed to the all applications page. Here, locate and click on the ‘Access Now’ button for Pabbly Connect to proceed to the dashboard.
In this step, you will create a workflow to facilitate the integration between Graphy and HubSpot. Click on the ‘Create Workflow’ button on the dashboard. A dialog box will prompt you to name your workflow. You can name it something like ‘Graphy Subscribers to HubSpot’. After naming, click on the ‘Create’ button to proceed. using Pabbly Connect
- Click on ‘Create’ to initialize the workflow.
Now, you will see options for setting up a trigger and an action. The trigger application will be Graphy, and the action application will be HubSpot. This setup allows you to automate the process of adding new subscribers from Graphy directly into HubSpot CRM.
3. Setting Up the Trigger with Graphy
Next, you will set up the trigger for your workflow. Select Graphy as your trigger application and choose the trigger event as ‘New Subscriber’. This event will initiate the workflow whenever a new subscriber is added in Graphy.
After selecting the trigger event, you will be provided with a webhook URL. This URL acts as a bridge connecting Pabbly Connect with Graphy. Copy this webhook URL, as you will need it in the next steps.
4. Configuring Graphy to Send Data to Pabbly Connect
Now, log in to your Graphy account and navigate to the Integrations section. Under third-party integrations, find Pabbly Connect. Here, you will select the event to send, which is ‘New Subscriber’. Paste the copied webhook URL from Pabbly Connect into the designated field. using Pabbly Connect
- Go to Graphy and open the Integrations section.
- Select ‘New Subscriber’ and paste the webhook URL.
After pasting the URL, click on the ‘Test’ button to ensure the webhook is working correctly. You should see a confirmation that the webhook has successfully triggered. Save your settings in Graphy to complete this step.
5. Setting Up HubSpot to Receive Data
With the trigger set up, the next step is to configure HubSpot as the action application in your workflow. Select HubSpot and choose the action event as ‘Create Contact’. You will be prompted to connect your HubSpot account to Pabbly Connect. Click on ‘Add New Connection’ to initiate the connection.
Once connected, you will need to map the information received from Graphy to the corresponding fields in HubSpot. Ensure that you fill in the first name, last name, email address, and phone number fields appropriately. After mapping the fields, click on ‘Save and Send Test Request’ to verify that the contact is created successfully in HubSpot.
By following these steps, you can seamlessly integrate Graphy subscribers into HubSpot using Pabbly Connect. This integration automates the process of adding new subscribers to your CRM, ensuring efficient management of your contacts. With Pabbly Connect, you can easily set up workflows that enhance your productivity and streamline your operations.
