Learn how to create new Campaign Monitor subscribers from Google Sheets in real-time using Pabbly Connect. Step-by-step tutorial for seamless integration. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start integrating Google Sheets with Campaign Monitor, first access Pabbly Connect. Open your browser and enter the URL for Pabbly Connect. It’s essential to work in incognito mode to avoid authentication issues with multiple Google accounts.
Once on the Pabbly Connect website, click on ‘Sign Up for Free’ or log in if you already have an account. After logging in, navigate to the app section and click on ‘Connect’ to access the integration features.
After accessing Pabbly Connect, you need to create a new workflow for the integration. Click on the ‘Create Workflow’ button, and a dialog box will appear prompting you to name your workflow. You can name it something like ‘Google Sheets to Campaign Monitor’.
- Click on ‘Create’ to establish the workflow.
- Select ‘Google Sheets’ as the app for the trigger event.
- Choose ‘New Spreadsheet Row’ as the trigger event.
After setting up the trigger, you will be prompted to connect your Google Sheets account, allowing Pabbly Connect to access your spreadsheet data.
3. Setting Up Google Sheets for Integration
Next, you need to set up your Google Sheets for integration with Pabbly Connect. Create a new Google Sheet and label it as ‘Data as Subscriber’. Ensure you have two columns: ‘Name’ and ‘Email’.
To integrate Google Sheets with Pabbly Connect, navigate to the ‘Add-ons’ menu, select ‘Pabbly Connect Webhooks’, and choose ‘Initial Setup’. Here, paste the webhook URL provided by Pabbly Connect into the designated field and specify the trigger column, which is usually the last data entry column.
4. Capturing Data in Pabbly Connect
After setting up Google Sheets, you can start capturing data. Fill in the ‘Name’ and ‘Email’ fields in your Google Sheet. For example, enter ‘Roger Stone’ and ‘[email protected]’. Once you do this, Pabbly Connect will automatically capture this data.
To confirm that the data has been captured, return to Pabbly Connect and check the captured data section. You should see the details you entered, including the name and email address, indicating the integration is working correctly.
5. Creating Subscribers in Campaign Monitor
Now that you have captured the data in Pabbly Connect, the next step is to create a subscriber in Campaign Monitor. In the action window, select ‘Campaign Monitor’ as the app and choose ‘Add Subscriber’ as the action event.
To connect to Campaign Monitor, you will need to provide your API key. Access your Campaign Monitor account settings to generate a new API key. Once you have copied the key, paste it into Pabbly Connect and save the connection.
- Select the list you want to add subscribers to.
- Map the email and name fields from the captured data.
- Click on ‘Save and Send Test Request’ to finalize the process.
After executing the test request, check your Campaign Monitor account to verify that the subscriber has been successfully added.
In this tutorial, we explored how to create new Campaign Monitor subscribers from Google Sheets in real-time using Pabbly Connect. By following the steps outlined, you can automate your subscriber management efficiently. This integration allows for seamless data transfer, enhancing your marketing efforts.
