Learn how to automate customer creation in WooCommerce from Google Ads leads using Pabbly Connect. Follow this step-by-step guide for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start integrating Google Ads leads with WooCommerce, access Pabbly Connect by visiting the official website. You can sign up for free if you are a new user or log in if you already have an account.
Once logged in, you will be directed to the Pabbly Connect dashboard where you can create new workflows. Click on the ‘Create Workflow’ button to initiate the integration process.
In this step, you will create a workflow that connects Google Ads leads with WooCommerce. First, name your workflow appropriately, such as ‘Create WooCommerce Customer for Google Ads Lead’. using Pabbly Connect
- Enter a name for your workflow.
- Select the folder where you want to save this workflow.
After naming your workflow, click on the ‘Create’ button. You will see two boxes: one for the trigger and one for the action. The trigger will be when a new lead is received from Google Ads, and the action will be to create a new customer in WooCommerce.
3. Setting Up the Trigger for Google Ads Leads
Now, you need to set up the trigger in Pabbly Connect. Choose Google Ads as your trigger application. You will need to provide the necessary Webhook URL to Google Ads, which acts as a bridge between the two applications.
To find the Webhook URL, go back to your Pabbly Connect workflow and copy the URL provided. Paste this URL into your Google Ads lead form settings under the lead delivery option.
- Open your Google Ads account and navigate to the lead form settings.
- Locate the lead delivery option and paste the Webhook URL.
- Test the integration to ensure data is being captured correctly.
Once this is set up, test the connection by sending a test lead from Google Ads to verify that it is received in your Pabbly Connect workflow.
4. Creating a WooCommerce Customer from Google Ads Lead
After confirming that the trigger works, the next step is to create a WooCommerce customer. In the action step of your workflow, select WooCommerce as the action application. Choose the action event as ‘Add New Customer’.
In this step, you will map the fields from the Google Ads lead to the WooCommerce customer fields. For example, map the lead’s first name, last name, email, and phone number to the corresponding fields in WooCommerce.
Select the WooCommerce action as ‘Add New Customer’. Map the fields from Google Ads lead to WooCommerce customer fields. Test the action to confirm that a new customer is created in WooCommerce.
Once you have successfully tested this action, you will see the new customer created in your WooCommerce account, confirming that the integration via Pabbly Connect is successful.
With the workflow set up, it’s crucial to finalize your integration. Ensure that all mappings are correct and that the workflow is activated. You can do this by clicking on the ‘Save’ button in your Pabbly Connect dashboard.
After saving, conduct a final test by submitting a lead through your Google Ads form. Check your WooCommerce account to ensure that the customer appears as expected.
Once confirmed, your integration is complete! You can now automate the process of creating WooCommerce customers from Google Ads leads efficiently using Pabbly Connect.
This tutorial demonstrated how to integrate Google Ads leads with WooCommerce using Pabbly Connect. By following these steps, you can automate customer creation and streamline your workflow effectively.
