Learn how to automate the enrollment of Thinkific users from Google Ads leads using Pabbly Connect in this detailed tutorial. Explore efficient methods for automating routine tasks with clear, concise instructions suited for both newcomers and experienced professionals.
1. Accessing Pabbly Connect for Google Ads Leads
To start automating the enrollment of Thinkific users from Google Ads leads, first, you need to access Pabbly Connect. Simply navigate to the Pabbly Connect website by typing ‘Pabbly.com/connect’ in your browser.
Once on the site, you will need to sign in to your Pabbly account. If you are a new user, click on ‘Sign Up for Free’ to create an account. This will grant you access to 100 free tasks monthly, which is perfect for setting up your automation.
After logging in, you will be directed to the Pabbly Connect dashboard. Here, you can create a new workflow to connect Google Ads with Thinkific. Click on the ‘Create Workflow’ button to begin. using Pabbly Connect
  • Name your workflow appropriately, such as ‘Enroll Thinkific User from Google Ads Lead’.
  • Select Google Ads as the trigger application.
  • Choose the trigger event as ‘New Lead’.
Once you have set up the trigger, you will need to connect your Google Ads account to Pabbly Connect. This is done by providing the necessary API credentials from your Google Ads account.
In this step, you will configure the trigger to capture leads from Google Ads. Select the lead form you want to use for this integration. This will ensure that every time a new lead is generated, it will trigger the workflow. using Pabbly Connect
To do this, you will copy the webhook URL provided by Pabbly Connect and paste it into the Google Ads lead form settings. This allows Pabbly Connect to receive data directly from Google Ads.
  • Navigate to your Google Ads account and find the lead form settings.
  • Locate the option for lead delivery and paste the webhook URL.
  • Save the changes to your lead form.
After saving, you can test the connection by submitting a test lead through your Google Ads lead form. This will allow you to confirm that Pabbly Connect is receiving the data correctly.
4. Enrolling Users in Thinkific Using Pabbly Connect
With the trigger set up, the next step is to enroll users in Thinkific. In your Pabbly Connect workflow, add an action step and select Thinkific as the application. using Pabbly Connect
Choose the action event as ‘Create User’. Here, you will need to provide the necessary user details such as first name, last name, email, and any other relevant information. This data will be pulled from the lead information captured from Google Ads.
Map the fields from Google Ads to the corresponding fields in Thinkific. Ensure that all required fields in Thinkific are filled correctly. Save the action step and send a test request to verify the integration.
Once the test is successful, you will see that the user has been created in your Thinkific account, confirming that the integration works smoothly.
After setting up the enrollment action, it’s time to finalize your workflow in Pabbly Connect. Review all the steps to ensure everything is correctly configured. using Pabbly Connect
Perform a final test by submitting another lead through your Google Ads lead form. Check both Pabbly Connect and your Thinkific account to confirm that the lead is processed and the user is enrolled successfully.
Once confirmed, you can activate your workflow, and it will run automatically from now on. This means every new lead from Google Ads will be seamlessly enrolled in Thinkific without any manual intervention.
In this tutorial, we explored how to integrate Google Ads leads with Thinkific using Pabbly Connect. This automation not only saves time but also streamlines the process of enrolling users in your online courses. By following the steps outlined, you can ensure a smooth and efficient workflow.
