Learn how to automate the process of creating Notion items for Google Ads leads using Pabbly Connect. Follow this step-by-step tutorial for seamless integration. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
1. Accessing Pabbly Connect for Google Ads to Notion Integration
To automate the process of creating Notion items for Google Ads leads, start by accessing Pabbly Connect. Navigate to the Pabbly website and log in to your account. If you are a new user, you can sign up for a free account, which offers 100 tasks per month.
After logging in, you will be directed to the Pabbly Connect dashboard. Here, you can create new workflows that connect your Google Ads leads with Notion. Click on the ‘Create New Workflow’ button to initiate the integration process.
2. Setting Up the Trigger for Google Ads Leads
The next step involves setting up the trigger event in Pabbly Connect. Select Google Ads as your trigger application and choose the event type as ‘New Lead.’ This action will initiate the automation whenever a new lead is generated in your Google Ads account.
- Choose Google Ads as the trigger application.
- Select ‘New Lead’ as the trigger event.
- Connect your Google Ads account by providing the necessary credentials.
Once you have set up the trigger, make sure to test the connection to ensure that Pabbly Connect can successfully receive data from Google Ads. If successful, you will be able to proceed to the next step.
3. Configuring Notion as the Action Application
After establishing the trigger, the next step is to configure Notion as the action application in Pabbly Connect. Select Notion from the action applications list and choose the action event as ‘Create Database Item.’ This will allow you to create a new item in your Notion database whenever a new lead is captured.
To connect your Notion account, you will need to log in and authorize Pabbly Connect to access your Notion workspace. Select the appropriate database where you want the leads to be added. Make sure to map the fields from Google Ads to the corresponding fields in Notion.
4. Mapping Fields Between Google Ads and Notion
In this section, you will map the fields from your Google Ads leads to the fields in your Notion database using Pabbly Connect. This step is crucial to ensure that the correct information is transferred accurately.
- Map the ‘First Name’ field from Google Ads to the corresponding field in Notion.
- Map the ‘Last Name’ field accordingly.
- Continue mapping all relevant fields such as email, phone number, and company name.
After mapping all necessary fields, click on the ‘Save and Send Test Request’ button to check if the data is being sent correctly to Notion. If the test is successful, you should see the new lead item created in your Notion database.
5. Testing and Activating Your Workflow
The final step is to test and activate your workflow in Pabbly Connect. Ensure that everything is set up correctly by sending a test lead from Google Ads. After completing the test, check your Notion database to verify that the item has been created successfully.
If the test is successful, you can activate your workflow. This means that every time a new lead is generated in Google Ads, Pabbly Connect will automatically create a corresponding item in your Notion database, streamlining your lead management process.
Integrating Google Ads leads with Notion using Pabbly Connect automates the process of lead management. By following this tutorial, you can save time and ensure that all your leads are organized efficiently in Notion.
