Learn how to integrate Formstack with Telegram using Pabbly Connect to receive form submissions directly in your Telegram account. Follow this detailed guide! Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start integrating Formstack with Telegram, you need to access Pabbly Connect. This platform allows you to automate workflows effortlessly. Begin by visiting the Pabbly Connect website and signing in to your account.
If you don’t have an account, click on the ‘Sign Up’ button. Once you log in, you will be directed to the dashboard where you can create a new workflow for your integration.
In this section, we will create a new workflow to connect Formstack with Telegram using Pabbly Connect. Start by clicking on the ‘Create Workflow’ button. A prompt will appear asking you to name your workflow.
- Choose a descriptive name for your workflow.
- Select ‘Formstack’ as your trigger application.
- Set the trigger event to ‘New Submission’.
After setting up the trigger, click on the ‘Save’ button. This will allow you to proceed to the next step where you will configure the action for Telegram.
3. Configuring Formstack to Send Data
Now, you will set up Formstack to send form submission data to Pabbly Connect. Go to your Formstack account and create a form if you haven’t already. Make sure your form includes fields that you want to capture.
Once your form is ready, navigate back to Pabbly Connect. You will need to connect your Formstack account by providing the necessary API key. After connecting, select the form you want to use for this integration.
4. Setting Up Telegram to Receive Submissions
The next step involves configuring Telegram to receive notifications from Pabbly Connect. In the Pabbly Connect dashboard, select Telegram as your action application. Choose the action event as ‘Send Message’.
- Connect your Telegram account by providing the bot token.
- Select the chat ID where you want to send messages.
- Customize the message format using the fields from your Formstack submission.
Once you have configured these settings, click on ‘Save & Send Test Request’ to ensure everything is working correctly.
5. Testing the Integration
After setting up both Formstack and Telegram in Pabbly Connect, it’s time to test the integration. Fill out your Formstack form with sample data and submit it. Check your Telegram to see if the message appears as expected.
If the message is sent successfully, you will see the details of the submission in your Telegram chat. This confirms that the integration is working perfectly. If you encounter any issues, revisit the settings in Pabbly Connect to ensure everything is configured accurately.
This tutorial demonstrated how to integrate Formstack with Telegram using Pabbly Connect. By following these steps, you can efficiently receive form submissions directly in your Telegram account, enhancing your workflow automation and communication.
