Learn how to create and update Mailercloud subscribers on FlexiFunnels purchases using Pabbly Connect in this detailed tutorial. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
To start creating and updating Mailercloud subscribers using Pabbly Connect, first, visit the Pabbly Connect website. You can access it by typing ‘Pabbly.com/connect’ into your browser. Once there, sign in to your Pabbly account. If you are a new user, you can sign up for free and get 100 tasks monthly.
After signing in, you’ll be directed to the Pabbly Connect dashboard. Here, you can manage all your workflows. To create a new workflow, click on the ‘Create Workflow’ button. You will then need to provide a name for your workflow, such as ‘Create/Update Mailercloud Subscriber on FlexiFunnels Purchase.’ Select a folder to save this workflow.
2. Creating the Workflow in Pabbly Connect
In this step, you will set up the workflow to automate the process of creating or updating Mailercloud subscribers when a purchase is made in FlexiFunnels. In your newly created workflow, you will see two boxes: ‘Trigger’ and ‘Action.’ The trigger is the event that starts the workflow, while the action is what happens as a result.
- Select ‘FlexiFunnels’ as your trigger application.
- Choose the trigger event as ‘New Purchase’.
After selecting the trigger, you will need to connect your FlexiFunnels account with Pabbly Connect. This is done by using a webhook URL provided by Pabbly Connect. Copy this URL and go to your FlexiFunnels account to set up the webhook for the product you are selling.
3. Setting Up the Webhook in FlexiFunnels
Now that you have the webhook URL from Pabbly Connect, you need to set it up in your FlexiFunnels account. Log in to FlexiFunnels, navigate to the product settings, and find the option to set rules for your products.
- Click on ‘Set Rules’ and then ‘Set Product Rules’.
- Paste the copied webhook URL from Pabbly Connect into the designated field.
Make sure to save your settings. This will ensure that whenever a purchase is made, FlexiFunnels will send the data to Pabbly Connect, triggering your workflow.
4. Creating or Updating Mailercloud Subscribers
Once the webhook is successfully set up, return to your Pabbly Connect workflow. Now, you will add an action step to create or update a subscriber in Mailercloud. Select Mailercloud as your action application.
In the action event, choose ‘Create/Update Subscriber’. You will then need to connect your Mailercloud account by entering the API key. This key can be found in your Mailercloud account under API settings. Once connected, you will set up the fields for the subscriber data.
5. Mapping Data in Pabbly Connect
In this final step, you will map the data received from FlexiFunnels to the fields required by Mailercloud. Use the mapping feature in Pabbly Connect to pull in the subscriber’s email, first name, last name, and any other necessary details from the webhook response.
After mapping all the required fields, click on ‘Save and Send Test Request’ to ensure everything is working correctly. Check your Mailercloud account to confirm that the subscriber has been created or updated successfully. If everything looks good, your integration is complete!
This tutorial has guided you through the process of integrating FlexiFunnels with Mailercloud using Pabbly Connect. By following these steps, you can automate the creation and updating of subscribers based on purchases made in FlexiFunnels, enhancing your email marketing efforts.
