Learn how to integrate Facebook with Doran using Pabbly Connect to automate post creation. Follow this detailed tutorial for seamless integration. Implement the precise methodologies leading organizations use to automate repetitive tasks, illustrated with practical examples designed for immediate application.
To start using Pabbly Connect, first, access the platform by searching for Pabbly.com/connect in your browser. This powerful automation tool allows you to seamlessly connect different applications, such as Doran and Facebook, for enhanced workflow efficiency.
If you’re a new user, click on the ‘Sign Up for Free’ button to create an account. Existing users can simply sign in. Upon signing up, you will receive 100 free tasks to explore the features of Pabbly Connect.
Once logged into Pabbly Connect, navigate to the dashboard where you can see all your workflows. Click on the ‘Create Workflow’ button on the right corner to start a new automation process. You will be prompted to name your workflow; for this example, name it ‘Create Post on Facebook Pages When Doran Post is Created’.
- Select Doran as the trigger application.
- Choose ‘Post Created’ as the trigger event.
After setting the trigger, you will get a webhook URL provided by Pabbly Connect. This URL is essential for linking your Doran account with Pabbly Connect.
3. Setting Up Doran for Integration
To integrate Doran with Pabbly Connect, log into your Doran account and navigate to the profile section. Here, go to the ‘Workspace’ and select ‘Integrations’. Click on ‘Pabbly Connect’ to start the integration process.
- Click on ‘Add New Webhook’.
- Paste the webhook URL copied from Pabbly Connect.
- Set the topic to ‘Post Created’.
After confirming the webhook, return to Pabbly Connect where it will show ‘Waiting for Webhook Response’. This means the integration is ready for testing.
4. Testing the Integration Between Doran and Facebook
Now that Doran is set up, create a new post in your Doran account to test the integration. Click on ‘Add New Post’ and fill in the title and content, then save the post. This action will trigger the webhook and send data to Pabbly Connect.
Once the post is created, go back to Pabbly Connect. You should see the response with the post details. This confirms that the connection between Doran and Pabbly Connect is successfully established.
5. Creating a Facebook Page Post from Doran
With the Doran post successfully created, now set up the action to create a Facebook post. In Pabbly Connect, select Facebook as the action application and choose the ‘Create Page Post’ event.
Connect your Facebook account to Pabbly Connect. Select the Facebook page where you want to post. Map the content from Doran to the Facebook post fields.
After mapping the necessary fields, save the settings and send a test request. If successful, check your Facebook page to see the new post created automatically from Doran.
In this tutorial, we explored how to integrate Doran with Facebook using Pabbly Connect. By following these steps, you can automate the process of posting updates from Doran directly to your Facebook page, enhancing your workflow efficiency.
