Learn how to integrate Facebook leads with Mailchimp and Insta Mojo using Pabbly Connect in this step-by-step tutorial. Build sophisticated automated workflows in less time than you think. This guide translates complex integrations into straightforward steps for immediate implementation.
To start using Pabbly Connect, first visit the Pabbly Connect dashboard. You can access it through the link provided in the video description. If you’re a new user, sign up for an account, which takes just a couple of minutes and gives you 100 free tasks.
After logging in, you’ll land on the dashboard. To create a new workflow, click on the ‘Create Workflow’ button on the right side. Name your workflow according to your objective, such as ‘Facebook Leads to Mailchimp and Insta Mojo’. Then, click ‘Create’ to proceed.
2. Setting Up Trigger for Facebook Lead Ads
In this section, we will set up the trigger for our workflow using Pabbly Connect. Select Facebook Lead Ads as your trigger application. The trigger event will be ‘New Lead Instant’. Click on ‘Connect’ to link your Facebook account.
- Choose ‘Add New Connection’ to authorize Pabbly Connect with your Facebook account.
- After successful authorization, select the Facebook page associated with your lead generation form.
- Click on ‘Save and Send Test Request’ to capture the lead data.
Once the lead data is captured, you can proceed to set up the next action in Pabbly Connect.
3. Adding Leads to Mailchimp
Now that we have our trigger set, we will add the captured leads to Mailchimp using Pabbly Connect. Choose Mailchimp as your action application and select ‘Add New Member with Custom Fields’ as the action event.
Click ‘Connect’ to link your Mailchimp account. You will need to enter your API key and data center information from your Mailchimp account. After connecting, you will set up the audience list and map the lead data, such as email address, first name, and last name.
- Ensure to map the email address and other fields correctly to avoid manual entry errors.
- You can also add tags like ‘New Subscriber’ to organize your leads.
After mapping the fields, click ‘Save and Send Test Request’ to confirm the integration is successful.
4. Creating Payment Link with Insta Mojo
Next, we will create a personalized payment link for the lead using Pabbly Connect. Select Insta Mojo as your action application and choose the action event ‘Create Payment Link’.
Connect to your Insta Mojo account by entering your private API key and auth token. Once connected, fill in the details for the payment link, including a title that includes the user’s name for personalization and the payment amount.
Ensure to set the payment link title dynamically using the lead’s name. Click ‘Save and Send Test Request’ to generate the payment link.
Once the payment link is generated, you can use it in the next step to send an email to the lead.
5. Sending Email with Gmail
Finally, we will send an email to the new lead with the payment link using Pabbly Connect. Choose Gmail as your action application and select ‘Send Email’ as the action event.
Connect to your Gmail account and fill in the recipient’s email address, subject, and email body. Make sure to map the payment link and personalize the email content to enhance user experience.
Include a friendly message thanking the user for subscribing and introducing the payment link. Click on ‘Save and Send Test Request’ to send the email.
Once the email is sent, you can verify if the lead received the email successfully, confirming the entire integration process is working flawlessly.
In this tutorial, we explored how to use Pabbly Connect to integrate Facebook leads with Mailchimp and Insta Mojo. By following these steps, you can automate your lead management process effectively, enhancing your marketing efforts.
