Learn how to integrate Facebook Lead Ads with Kit using Pabbly Connect. Follow our detailed tutorial for seamless automation. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To start integrating Facebook Lead Ads with Kit, first access Pabbly Connect by visiting its website. Here, you can sign in or create a new account if you’re a new user. Simply click on the ‘Sign Up for Free’ button to get started, which offers 100 free tasks monthly.
Once logged in, navigate to the dashboard where you can find all your workflows. Click on the ‘Pabbly Connect’ option to access the integration tools. This platform is essential for automating the process between Facebook Lead Ads and Kit, allowing you to manage your leads effectively.
To create a new workflow, click on the ‘Create Workflow’ button in the dashboard. Name your workflow something like ‘Create Kit Subscriber for Facebook Lead Ads’ and select the appropriate folder for organization. This name will help you identify the workflow easily later. using Pabbly Connect
  • Click on the ‘Create’ button after naming your workflow.
  • A trigger and action box will appear for setting up the automation.
  • Select Facebook Lead Ads as your trigger application.
After setting the trigger, you can configure the action application. This step is crucial as it defines what happens when a new lead is received. In this case, the action will be to create a subscriber in Kit.
3. Configuring Facebook Lead Ads in Pabbly Connect
Next, configure the Facebook Lead Ads as the trigger application in Pabbly Connect. Choose the ‘New Lead Instant’ event to ensure that every new lead will trigger the workflow. Click on ‘Connect’ to link your Facebook account.
After connecting, you’ll need to select the Facebook page and the lead form you want to use. For instance, choose your page named ‘Natural Glow Skincare’ and select the corresponding lead form. This is where the leads will come from, ensuring accurate data collection.
  • Enter the page name and lead form as per your Facebook account.
  • Click on ‘Save and Send Test Request’ to check the connection.
  • Perform a test submission in your Facebook Lead Ads to validate the integration.
Once the test is successful, you will see the lead details captured in Pabbly Connect, confirming that the connection between Facebook Lead Ads and Pabbly Connect is working effectively.
4. Setting Up Kit Integration in Pabbly Connect
Now that you have configured Facebook Lead Ads, it’s time to set up Kit as the action application in Pabbly Connect. Select Kit and then choose the action event as ‘Tag a Subscriber’. This action will create a new subscriber in your Kit account whenever a new lead is received from Facebook.
To connect Kit, you will need to enter your API key and API secret. You can find these details in your Kit account under the account settings. Make sure to copy and paste them correctly into Pabbly Connect to establish a successful connection.
Enter the tag ID for the subscriber, which you can create in your Kit account. Map the fields such as email address and first name from the previous response. Click on ‘Save and Send Test Request’ to verify the action.
After successfully saving, you can check your Kit account to confirm that the subscriber has been created under the specified tag. This seamless integration showcases how Pabbly Connect simplifies the process of managing leads.
5. Testing the Integration for Success
Finally, it’s essential to test the entire integration to ensure everything is working as expected. Go back to your Facebook Lead Ads testing tool and submit a new lead form with different details. This will help confirm that the integration is functioning correctly.
After submitting the form, check your Kit account again to see if the new subscriber appears under the same tag. If the details match, it indicates that the integration via Pabbly Connect is successful and operational.
Delete the previous lead before submitting a new one to avoid duplicates. Refresh your Kit account page to view the latest subscribers. Repeat the process to ensure consistent results.
By completing these steps, you can confidently say that you have successfully integrated Facebook Lead Ads with Kit using Pabbly Connect. This automation not only saves time but also enhances your lead management strategy.
In this tutorial, we explored how to integrate Facebook Lead Ads with Kit using Pabbly Connect. By following the detailed steps, you can automate the process of creating subscribers, enhancing your business efficiency. With Pabbly Connect, managing leads has never been easier.
