Learn how to automate lead management by integrating Elementor with Go High Level using Pabbly Connect. Step-by-step guide for seamless automation. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Introduction to Pabbly Connect Integration
Pabbly Connect serves as a powerful integration platform that automates workflows between applications like Elementor and Go High Level. This integration allows for seamless lead management by automatically creating contacts in Go High Level whenever a new form submission is made in Elementor.
Using Pabbly Connect, you can eliminate the manual process of transferring leads, saving time and reducing errors. In this tutorial, we will guide you through the steps to set up this integration effectively.
2. Accessing Pabbly Connect for Integration
To begin, navigate to the Pabbly Connect website and log into your account. If you’re new to Pabbly Connect, you can sign up for a free account, which offers 100 free tasks every month. Once logged in, you will see the dashboard with various applications listed.
Click on the ‘Access Now’ button for Pabbly Connect to access the dashboard where you will create a new workflow. This is where your automation process will begin.
3. Creating a Workflow in Pabbly Connect
To create a new workflow, click on the ‘Create Workflow’ button located in the top right corner of the dashboard. A dialog box will appear, prompting you to enter a workflow name and select a folder for organization. For example, name your workflow ‘Create or Update Go High Level Contact on Elementor Form Submission’. using Pabbly Connect
After naming your workflow, select a folder from the dropdown menu. You might have a folder named ‘Elementor Automations’ with a subfolder called ‘New Form Submission’. Select this subfolder and click the ‘Create’ button to finalize your workflow setup.
4. Setting Up the Trigger in Pabbly Connect
In this section, you will set up the trigger for your workflow. Select ‘Elementor’ as the trigger application and choose ‘New Form Submission’ as the trigger event. Once selected, Pabbly Connect will provide you with a unique webhook URL. using Pabbly Connect
Copy this webhook URL and navigate to your Elementor form settings. Under the ‘Action After Submit’ section, add an action and search for ‘Webhook’. Paste the webhook URL into the designated field and save your changes. This step ensures that every time a form is submitted, Pabbly Connect captures the response.
- Select Elementor as the trigger application.
- Choose New Form Submission as the trigger event.
- Paste the webhook URL into your Elementor form settings.
After saving the changes in Elementor, return to Pabbly Connect and you will see that it is waiting for a webhook response. This indicates that your trigger is set up correctly.
5. Setting Up the Action in Pabbly Connect
Now that the trigger is configured, it’s time to set up the action step. Select ‘Lead Connector V2’ as your action application, which corresponds to Go High Level. Choose ‘Create or Update Contact’ as the action event. Click on the ‘Connect’ button to establish a connection. using Pabbly Connect
Once connected, you will be prompted to map the data from the Elementor form submission to the fields in Go High Level. For example, map the first name, last name, email, and phone number from the previous step. Each time a form is submitted, Pabbly Connect will automatically create or update the contact in Go High Level.
- Select Lead Connector V2 as the action application.
- Choose Create or Update Contact as the action event.
- Map the required fields from the Elementor response.
After mapping the fields, click on the ‘Save and Send Test Request’ button to verify that the integration works correctly. Check your Go High Level account to confirm that the new contact has been successfully created.
In this tutorial, we demonstrated how to integrate Elementor with Go High Level using Pabbly Connect. This automation streamlines the process of managing leads by automatically capturing form submissions and creating contacts in your CRM. By following these steps, you can enhance your lead management process significantly.
