Learn how to integrate Elementor forms with Mailgun using Pabbly Connect to automate subscriber additions effortlessly. Explore systematic approaches to creating efficient automation solutions that convert technical concepts into practical, implementable instructions.
To integrate Elementor with Mailgun, start by accessing Pabbly Connect. This platform is essential for automating the process of adding subscribers from Elementor forms to Mailgun mailing lists. First, sign up for a free account, which provides 100 free automation tasks each month.
After logging into your Pabbly Connect account, you will be directed to the dashboard. Here, you can create a new workflow to set up the integration between Elementor and Mailgun, streamlining your email marketing efforts.
Once on the dashboard, click on the ‘Create Workflow’ button to initiate the process. Name your workflow, such as ‘Add Subscribers from Elementor Forms to Mailgun Automatically’. This name will help you identify the workflow later. using Pabbly Connect
- Click on ‘Create’ to establish your workflow.
- You will see options for ‘Trigger’ and ‘Action’.
- Set the trigger to ‘New Form Submission’ from the Elementor Forms application.
With the trigger set, you can now proceed to configure the action that will follow the form submission. This step is crucial as it connects the data collected from Elementor to your Mailgun account.
3. Setting Up the Elementor Trigger in Pabbly Connect
To set up the Elementor trigger, select Elementor Forms as the trigger application in Pabbly Connect. Choose the event ‘New Form Submission’. This event will activate your workflow whenever someone submits a form created with Elementor.
After selecting the trigger, Pabbly Connect will provide you with a webhook URL. This URL is essential for connecting your Elementor form to Pabbly Connect. Copy this URL to use it in the next steps.
- Navigate to your WordPress dashboard and edit the Elementor form.
- In the form settings, locate ‘Actions After Submit’ and add ‘Webhook’.
- Paste the webhook URL you copied from Pabbly Connect.
After updating the form, your Elementor form is now connected to Pabbly Connect, ready to send data upon submission.
4. Adding Mailgun as an Action in Pabbly Connect
Next, you will need to set up Mailgun as the action application in your Pabbly Connect workflow. Search for Mailgun and select it as your action application. Choose the action event as ‘Add New Mailing List Member’. This action will automatically add the new subscriber to your Mailgun list.
Click on ‘Connect’ and create a new connection by entering your Mailgun API key and other required details. You can find your API key in your Mailgun account under the security settings. Make sure to select the correct region and domain name corresponding to your Mailgun setup.
Input your Mailgun API key and host region. Select the domain from your Mailgun account that matches the region. Save the connection to finalize the setup.
With Mailgun connected, you can now map the data received from Elementor to create a new member in your mailing list.
5. Mapping Data to Mailgun in Pabbly Connect
In this step, map the data fields from the Elementor form submission to the corresponding fields in Mailgun. This mapping ensures that the correct information is sent to Mailgun when a form is submitted. Select the mailing list where you want to add the new subscriber.
For the email address and member name, you can directly map the fields from the Elementor submission data captured by Pabbly Connect. Make sure to set the update option according to your preference, allowing for either updates to existing members or raising errors for duplicates.
Map the email address field from Elementor to Mailgun. Map the member name field similarly. Test the connection by sending a test request.
Upon successful testing, your workflow is complete. Now, whenever someone submits the Elementor form, their details will be automatically added to your Mailgun mailing list, enhancing your marketing automation.
Integrating Elementor forms with Mailgun using Pabbly Connect streamlines your subscriber management process. By following these steps, you can automate the addition of subscribers to your mailing list, saving you time and boosting productivity. Start leveraging Pabbly Connect today for seamless integrations!
