Learn how to integrate Elementor Forms submissions with Flowlu as contacts using Pabbly Connect. Follow this detailed tutorial for step-by-step guidance. Eliminate manual repetitive tasks from your workflow. Discover proven automation methods with intuitive steps designed for efficiency-minded professionals.
1. Overview of Pabbly Connect for Elementor and Flowlu Integration
Pabbly Connect is a powerful automation tool that enables seamless integration between different software applications. In this tutorial, we will utilize Pabbly Connect to connect Elementor Forms with Flowlu, allowing automatic addition of form submissions as contacts in your Flowlu CRM.
To begin, you need to have both Elementor and Flowlu accounts set up. This integration will automate the process, ensuring that every time a user submits a form on your website, their details are captured and added to your Flowlu account without any manual input.
2. Creating Your Pabbly Connect Account
To start using Pabbly Connect, visit the Pabbly website and navigate to the Pabbly Connect section. If you’re a new user, click on the ‘Sign Up for Free’ button to create your account. You can set up your account in just two minutes.
Once your account is created, you will receive 100 free tasks every month. If you already have an account, simply sign in and access the Pabbly Connect dashboard. Here, you can create a new workflow for your integration.
3. Setting Up the Workflow in Pabbly Connect
Now that you are logged into Pabbly Connect, create a new workflow by clicking on the plus sign and selecting ‘Create Workflow’. Name your workflow something descriptive, like ‘Add Elementor Form Submissions to Flowlu as Contacts’. This name will help you identify the workflow later.
In the workflow setup, you will see two sections: Trigger and Action. For the Trigger, choose Elementor Forms and select ‘New Form Submission’ as the trigger event. This setup will initiate the workflow whenever a form is submitted via Elementor.
- Select Elementor Forms as the application.
- Copy the Webhook URL provided by Pabbly Connect.
After copying the Webhook URL, you will need to set this up in your Elementor form settings to capture the data correctly.
4. Configuring Elementor to Use Pabbly Connect Webhook
To configure your Elementor form to send data to Pabbly Connect, go to your WordPress dashboard and edit the page where your form is located. Click on the form to access its settings and find the ‘Actions After Submit’ option. Here, you will add a new action by clicking the plus sign and selecting Webhook.
Paste the Webhook URL you copied from Pabbly Connect into the designated field and save the changes. This setup ensures that every time a form is submitted, the data is sent to Pabbly Connect for processing.
5. Adding Flowlu Connection in Pabbly Connect
With your Elementor form configured, return to Pabbly Connect to set up the action that will add the form submissions as contacts in Flowlu. In the Action section of your workflow, select Flowlu and choose ‘Create CRM Contact’ as the action event.
You will need to connect your Flowlu account by entering your API key and account URL, which you can find in your Flowlu account settings. Once connected, map the fields from your Elementor form submission to the corresponding fields in Flowlu, such as first name, last name, and email.
- Input your Flowlu API Key and Account URL.
- Map the first name, last name, and email address from the form submission.
- Test the connection to ensure the contact is created successfully.
Once the mapping is complete and tested, save your workflow in Pabbly Connect. This will finalize the integration process.
In this tutorial, we demonstrated how to integrate Elementor Forms with Flowlu using Pabbly Connect. By following these steps, you can automate the process of adding form submissions as contacts in your CRM, saving time and reducing manual work. With Pabbly Connect, you can streamline your workflows and enhance your productivity.
