Learn how to integrate ClickFunnels with Shopify using Pabbly Connect. This step-by-step guide will walk you through the entire process seamlessly. Revolutionize your productivity approach with just a few strategic clicks. Uncover professional methods for connecting applications and creating workflows that reclaim hours of your week.
To start integrating ClickFunnels with Shopify, you need to access Pabbly Connect. Begin by visiting the Pabbly website and selecting the option to sign up for a new account or log in if you are already a user. This process will allow you to utilize the integration features of Pabbly Connect effectively.
Once logged in, navigate to the dashboard of Pabbly Connect. Here, you can create a new workflow that will automate the process of adding new customers to Shopify whenever a new contact is created in ClickFunnels. This automation is crucial for streamlining your online sales operations.
Creating a workflow in Pabbly Connect involves a few steps. First, click on the ‘Create Workflow’ button and provide a name for your workflow. For this integration, you might name it ‘Create Shopify Customers from ClickFunnels Contacts’. After naming, select the folder where you want to save this workflow.
 - You will see two windows for Trigger and Action applications.
 - Select ClickFunnels as your Trigger application.
After selecting ClickFunnels, choose the trigger event as ‘New Contact Created’. This event will initiate the workflow whenever a new contact is added in ClickFunnels, capturing the necessary details to be sent to Shopify via Pabbly Connect.
3. Connecting ClickFunnels to Pabbly Connect
To connect ClickFunnels to Pabbly Connect, you will need to copy the webhook URL provided in the dashboard. This URL acts as a bridge between ClickFunnels and Pabbly Connect. Navigate to your ClickFunnels account, go to the ‘Settings’ section, and locate the ‘Webhooks’ option.
- Click on ‘Add New Endpoint’.
 - Enter a name for your webhook, such as ‘New Contacts’.
 - Paste the copied webhook URL into the URL field.
 - Select the event type as ‘Contact Created’.
After setting this up, click on the ‘Create Endpoint’ button to finalize the connection. Now, Pabbly Connect will be ready to capture new contact data from ClickFunnels.
4. Creating a Customer in Shopify Through Pabbly Connect
With ClickFunnels connected, the next step involves setting up Shopify as the action application in Pabbly Connect. Select Shopify and choose the action event ‘Create Customer’. This action will ensure that a new customer is created in your Shopify store whenever a new contact is registered in ClickFunnels.
To establish this connection, you will need to enter your Shopify store’s subdomain and the Admin API access token. The subdomain can be found in your Shopify store URL, and the API token is generated by creating a new app in your Shopify account. Make sure to enable the necessary permissions for customer management while creating the app.
5. Mapping Data Between ClickFunnels and Shopify
After setting up the Shopify action in Pabbly Connect, you will need to map the data from ClickFunnels to Shopify. This step is crucial as it ensures that the customer details are accurately transferred. Select the corresponding fields such as first name, last name, email, and phone number from the ClickFunnels response.
Map the first name field from the ClickFunnels data. Continue mapping last name, email, and phone number fields. Ensure that all mapped fields are correctly aligned to avoid errors.
Once mapping is complete, click on ‘Save and Send Test Request’ to verify the integration. If successful, check your Shopify account to confirm that the new customer has been created as expected. This seamless integration is made possible through Pabbly Connect, allowing for efficient data handling between the two applications.
In this tutorial, we explored how to integrate ClickFunnels with Shopify using Pabbly Connect. By following these detailed steps, you can automate the creation of new customers in Shopify whenever a new contact is added in ClickFunnels. This integration not only saves time but also enhances your business efficiency.
