Learn how to seamlessly integrate ClickBank with ActiveCampaign using Pabbly Connect to automate adding new contacts for sales. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
To begin the integration of ClickBank with ActiveCampaign, first, access Pabbly Connect by visiting Pabbly.com/connect. This platform is essential for automating the process of adding contacts from ClickBank sales to ActiveCampaign.
Once on the site, you can either sign up for a new account or log into your existing account. After logging in, navigate to the dashboard where you can create a new workflow specifically for this integration.
In Pabbly Connect, click on ‘Create Workflow’ and name it something descriptive, like ‘ClickBank to ActiveCampaign’. This workflow will handle the automation between the two applications.
Each workflow in Pabbly Connect consists of a trigger and an action. For this integration, the trigger will be a new sale in ClickBank, and the action will be to add the customer as a new contact in ActiveCampaign.
- Click on ‘Create Workflow’.
- Name your workflow (e.g., ClickBank to ActiveCampaign).
- Define the trigger as ‘New Sale’ in ClickBank.
After setting up the initial workflow, you will see two sections: the trigger and the action. This setup will allow Pabbly Connect to listen for new sales in ClickBank and execute the corresponding action in ActiveCampaign.
3. Setting Up ClickBank in Pabbly Connect
To connect ClickBank, select it as your trigger app in Pabbly Connect and choose the event ‘New Sale’. This will generate a webhook URL that you need to copy.
Next, navigate to your ClickBank account, go to ‘Vendor Settings’, and paste the webhook URL into the ‘Instant Notification’ section. Test the connection by sending a test sale to ensure that ClickBank is properly communicating with Pabbly Connect.
- Select ClickBank as the trigger app.
- Choose ‘New Sale’ as the trigger event.
- Copy the webhook URL and paste it in ClickBank under ‘Vendor Settings’.
After testing the connection, you should receive a confirmation in Pabbly Connect indicating that the new sale data has been received successfully.
4. Decrypting Sale Data Using Pabbly Connect
Once the new sale data is received in Pabbly Connect, it will be in an encrypted format. To decrypt this data, you will use the Data Transformer feature within Pabbly Connect.
Set up the Data Transformer by selecting it as an action app and mapping the necessary fields such as the secret key, notification, and IV. This will allow you to extract the customer’s details from the encrypted data received from ClickBank.
Select Data Transformer as the action app. Map the secret key, notification, and IV from the ClickBank response. Click ‘Save and Send Test Request’ to decrypt the data.
After successfully decrypting the data, you will have access to the customer’s email, name, and other relevant information needed to add them as a contact in ActiveCampaign.
5. Adding Contact to ActiveCampaign via Pabbly Connect
Finally, to add the newly decrypted customer information to ActiveCampaign, choose ActiveCampaign as the action app in Pabbly Connect and select ‘Create or Update Contact’ as the action event.
Map the fields such as email, first name, and last name using the data extracted from ClickBank. After mapping the fields, click on ‘Save and Send Test Request’ to verify that the contact is added successfully to ActiveCampaign.
Select ActiveCampaign as the action app. Choose ‘Create or Update Contact’ as the action event. Map the required fields and send the test request.
Once the test is successful, you can check your ActiveCampaign account to confirm that the new contact has been added, completing the integration process using Pabbly Connect.
In this tutorial, we explored how to use Pabbly Connect to automate the process of adding new contacts to ActiveCampaign for every sale made on ClickBank. By following the steps outlined, you can efficiently manage your contacts and enhance your marketing efforts.
With Pabbly Connect, integrating multiple applications becomes seamless, allowing you to focus on growing your business without manual data entry.
