Learn how to automate the process of creating or updating MailerLite subscribers on Cashfree payments using Pabbly Connect with this step-by-step tutorial. Discover hidden automation capabilities within your existing tools. This guide shows you how to connect your essential applications and permanently eliminate redundant manual processes.
1. Introduction to Pabbly Connect for Cashfree and MailerLite Integration
In this section, we will explore how to use Pabbly Connect to integrate Cashfree Payments with MailerLite. This integration allows you to automate the process of adding or updating subscribers in MailerLite whenever a payment is made through Cashfree. By leveraging Pabbly Connect, you can streamline your email marketing efforts and enhance customer engagement.
To start, you need to access Pabbly Connect. Simply visit the Pabbly Connect website and log in to your account. If you are a new user, you can sign up for a free trial that allows you to explore the features available. Once logged in, you will be directed to the dashboard where you can create workflows that connect various applications seamlessly.
To create a new workflow in Pabbly Connect, click on the ‘Create Workflow’ button located at the top right corner of your dashboard. In the dialog box that appears, give your workflow a name, such as ‘Create or Update MailerLite Subscriber on Cashfree Payment.’ Choose a folder to save your workflow, or create a new one if necessary.
- Click on ‘Create’ to initiate your workflow.
- Select Cashfree as the trigger application.
- Set the trigger event to ‘Payment via Form’ to capture payment submissions.
After setting up the trigger, Pabbly Connect will provide you with a webhook URL. This URL is crucial for connecting your Cashfree account with Pabbly Connect. Copy this URL as you will need it in the next steps.
3. Connecting Cashfree to Pabbly Connect
To connect Cashfree to Pabbly Connect, log into your Cashfree account and navigate to the developer section. Under the ‘Payment Gateway’ option, find the ‘Webhooks’ section. Here, you will add a new webhook endpoint.
- Click on ‘Add Webhook Endpoint’.
- Paste the webhook URL copied from Pabbly Connect.
- Test the webhook to ensure it is set up correctly.
Once the webhook is added, Pabbly Connect will be ready to receive data from Cashfree whenever a payment is made. This connection is crucial for the automation to function effectively.
4. Setting Up MailerLite Integration in Pabbly Connect
After successfully connecting Cashfree, the next step is to integrate MailerLite using Pabbly Connect. In your workflow, select MailerLite as the action application. Choose the action event as ‘Create or Update Subscriber.’ This allows you to manage your subscriber list based on the payment data received.
To establish this connection, you will need to provide an API token from your MailerLite account. Go to the Integrations section in MailerLite, generate a new API token, and paste it into Pabbly Connect. This token will allow Pabbly Connect to securely access your MailerLite account.
Map the subscriber email field with the email received from Cashfree. Set the subscriber status to active. Optionally, map additional fields like name and phone number.
After mapping the necessary fields, click on ‘Save and Send Test Request’ to verify that the integration is working correctly. This step ensures that a new subscriber is created or updated in MailerLite whenever a payment is processed through Cashfree.
To test the complete integration, go back to your Cashfree account and perform a test payment using the payment form you set up earlier. Ensure that you fill in all required fields accurately. Once the payment is processed, Pabbly Connect should capture the payment details and execute the workflow.
Check your MailerLite account to confirm that the new subscriber has been added. Refresh the subscribers’ list to see the newly created or updated subscriber details. This test verifies that the integration between Cashfree and MailerLite via Pabbly Connect is functioning as intended.
By automating this process, you save time and ensure that your email marketing efforts are efficient and effective. With Pabbly Connect, you can easily manage your subscribers without manual intervention.
Integrating Cashfree Payments with MailerLite using Pabbly Connect is a straightforward process that enhances your email marketing capabilities. By following the steps outlined in this tutorial, you can automate subscriber management based on payment activity. This not only saves time but also improves customer engagement through timely communications.
Utilizing Pabbly Connect for this integration allows for seamless workflows and better management of your online business operations. Start automating today to take full advantage of these powerful tools!
