Learn how to create and update Mailercloud subscribers through Cashfree payments using Pabbly Connect in this detailed tutorial. Perfect for automating your workflows! This comprehensive guide reveals exactly how to connect your applications and automate repetitive tasks — accessible for professionals of all technical backgrounds.
To initiate the integration of Cashfree and Mailercloud, you first need to access Pabbly Connect. Begin by visiting the Pabbly website and signing in to your account. If you don’t have an account, sign up for free to get started.
Once you log in, navigate to the Pabbly Connect dashboard. Here, you can create a new workflow that will facilitate the connection between Cashfree and Mailercloud. This is where the automation happens, allowing you to create or update Mailercloud subscribers automatically whenever a payment is made through Cashfree.
In this section, you will create a workflow specifically for updating Mailercloud subscribers when a payment occurs in Cashfree. Click on the ‘Create Workflow’ button and name it ‘How to Create or Update Mailercloud Subscriber on Cashfree Payment’ to keep it organized. using Pabbly Connect
Next, you will need to set up the trigger event. Since you want to automate this process, select Cashfree as the trigger application. The trigger event will be set to ‘Payment Form Submission.’ This means every time a payment is submitted through Cashfree, it will trigger the workflow.
- Name the workflow appropriately.
- Select Cashfree as the trigger application.
- Choose ‘Payment Form Submission’ as the trigger event.
After setting the trigger, Pabbly Connect will provide you with a webhook URL. This URL is crucial as it acts as a bridge between Cashfree and Pabbly Connect. You will need to copy this URL and set it up in your Cashfree account.
Setting Up Cashfree Webhook
Now that you have the webhook URL from Pabbly Connect, it’s time to set it up in your Cashfree account. Log in to Cashfree and go to the ‘Developers’ section. Here, select ‘Webhooks’ and click on ‘Add Webhook’.
In the webhook settings, paste the URL you copied from Pabbly Connect into the designated field. This will ensure that every time a payment is made, Cashfree sends the payment details directly to Pabbly Connect, which will then process this information and trigger the next steps in your workflow.
- Navigate to the ‘Developers’ section in Cashfree.
- Select ‘Webhooks’ and click on ‘Add Webhook’.
- Paste the Pabbly Connect webhook URL.
After adding the webhook, test it to ensure that Cashfree is sending the correct data to Pabbly Connect. You can do this by making a test payment through Cashfree and checking if Pabbly Connect receives the payment data.
Creating or Updating Mailercloud Subscriber
With the webhook successfully set up, the next step is to configure the action in Pabbly Connect to create or update a subscriber in Mailercloud. Select Mailercloud as the action application and choose the ‘Create/Update Subscriber’ action event. using Pabbly Connect
In this step, you will need to map the fields from the Cashfree payment response to the Mailercloud subscriber fields. This includes the email address, first name, and any other relevant details that you want to capture. Using Pabbly Connect’s mapping feature, select the respective fields from the Cashfree response to ensure the data flows correctly into Mailercloud.
Select Mailercloud as the action application. Choose ‘Create/Update Subscriber’ as the action event. Map the fields from Cashfree to Mailercloud.
After mapping the fields, finalize the setup by testing the action. Send a test request to Mailercloud to verify that the subscriber is created or updated successfully. Once confirmed, your workflow is now complete and will automatically create or update Mailercloud subscribers whenever a payment is processed through Cashfree.
This tutorial demonstrated how to integrate Cashfree and Mailercloud using Pabbly Connect. By following these steps, you can automate the process of creating or updating Mailercloud subscribers with each payment made through Cashfree, enhancing your workflow efficiency.
