Learn how to integrate applications like Facebook, YouTube, and more using Parameter Based Authentication inside Pabbly Connect with this detailed step-by-step tutorial. Learn to create powerful connections between your critical applications without requiring specialized programming knowledge or extensive technical background.
To begin integrating applications using Pabbly Connect, first navigate to the Pabbly Connect dashboard. This is where you will manage your integrations seamlessly. You can access the backend developer platform by entering connect.Pabbly.com/app in your browser.
Once you are on the application integration page, click on the ‘Create New App’ button. Here, you will need to name your application and save it. For demonstration purposes, we will refer to the email marketing application, MooseSend, which uses parameter-based authentication.
2. Setting Up Application Details in Pabbly Connect
After creating your application in Pabbly Connect, the next step is to enter specific details about the application. This includes the application’s name, description, and logo, which should be 64×64 pixels. You will also select the authentication type, which in this case is ‘Parameter’ based on the API documentation of MooseSend.
- Enter the application name and description.
- Upload the application logo.
- Select ‘Parameter’ as the authentication type.
Once you have filled out these details, create a parameter for the API key. This parameter will collect the API key from the user. Click on the settings button to configure the label and description for the API key field. This setup allows users to understand what information they need to provide.
3. Creating Triggers in Pabbly Connect
Next, you will create triggers that will initiate actions within Pabbly Connect. Go to the trigger section and click on the ‘Create Trigger’ button. You will need to enter a name for your trigger event and a description of what it does. For this integration, we will create a trigger called ‘New Subscriber’.
Choose the trigger type based on how your application supports webhooks. MooseSend allows users to manually enter the webhook URL, so select ‘Webhook Setup by Instruction’. Additionally, provide instructions for users on how to set up this webhook within their MooseSend account.
- Enter the trigger name and description.
- Select the trigger type as ‘Webhook Setup by Instruction’.
- Provide detailed instructions for users.
After saving your trigger, you can proceed to create additional triggers as necessary to enhance the integration capabilities of your application.
4. Building Actions in Pabbly Connect
Once the triggers are set, it’s time to build actions using Pabbly Connect. Navigate to the action section and click on the ‘Create New Action’ button. Similar to triggers, you will enter the action name and description. For this integration, we will create an action called ‘Add New Subscriber’.
In this step, you will need to configure the API call for the action. Select the appropriate HTTP method and enter the API endpoint URL required to add a new subscriber to the MooseSend account. Since MooseSend uses parameter-based authentication, ensure that you pass the API key as a parameter in your API call.
Enter the action name and description. Select the HTTP method and enter the API endpoint. Configure the parameters needed for the API call.
After configuring the action, you can test it to ensure that it works as expected. This testing phase is crucial for verifying that the integration is functioning correctly.
5. Finalizing Integration in Pabbly Connect
With your triggers and actions set up, you can now finalize the integration in Pabbly Connect. Go back to the workflow you created earlier and select the MooseSend app. Choose the action event ‘Add New Subscriber’ and connect your MooseSend account using the API key.
After entering the API key, you will see options to select the mailing list and input the subscriber’s name and email address. Fill in these details and click on ‘Save and Test Request’. Upon successful execution, you will receive a positive response indicating that the subscriber has been added to the MooseSend account.
By following these steps, you can continuously add triggers and actions, thereby enhancing your application’s capabilities within Pabbly Connect. You can also share your integrated application with others once it is fully functional.
This tutorial provided a detailed guide on how to integrate applications using Parameter Based Authentication inside Pabbly Connect. By following the steps outlined, you can successfully connect various applications and automate workflows efficiently.
