Learn how to create or update ActiveCampaign contacts for Instamojo payments using Pabbly Connect in this step-by-step tutorial. Develop expertise in application integration and learn how to design streamlined automation workflows using proven, simplified approaches.
To start integrating ActiveCampaign with Instamojo, you first need to access Pabbly Connect. This platform is essential for automating the process of creating or updating contacts in ActiveCampaign whenever a payment is made through Instamojo.
Visit the Pabbly Connect website by entering ‘Pabbly.com/connect’ in your browser. If you already have an account, click on the ‘Sign In’ button at the top right corner. New users can create an account by clicking on ‘Sign Up for Free’ and will receive 100 free tasks monthly.
Once logged into Pabbly Connect, navigate to the dashboard where you can create a new workflow. Click on the ‘Create Workflow’ button. You will be prompted to name your workflow, so enter a name like ‘Create or Update ActiveCampaign Contact for Instamojo Payment’ and select a folder to save it in.
- Click on the ‘Create’ button after naming your workflow.
- You will see two boxes appear: one for Trigger and one for Action.
- Select ‘Webhook’ as the Trigger application.
After setting up the trigger, you will need to define what happens when a payment occurs in Instamojo. This is where Pabbly Connect automates the entire process, ensuring that every new payment results in an updated or created contact in ActiveCampaign.
3. Setting Up Webhook in Instamojo
In the workflow, select Instamojo as the trigger event to capture payment details. You will need to provide a Webhook URL from Pabbly Connect to your Instamojo account. This URL acts as a bridge between the two applications. using Pabbly Connect
To find the Webhook URL, go back to Pabbly Connect and copy the generated URL. Then, log in to your Instamojo account, navigate to the settings, and find the Webhook section. Paste the copied URL into the Webhook settings and select the events you want to trigger the workflow.
- Choose ‘Successful Payment’ as the event to trigger the workflow.
- Save the settings to ensure the Webhook is activated.
Once the Webhook is set, you can perform a test payment to ensure that Pabbly Connect receives the data correctly. This step is crucial to confirm that your integration is working as expected.
4. Configuring ActiveCampaign in Pabbly Connect
After verifying that the Webhook is working, the next step is to set up ActiveCampaign as the action application in Pabbly Connect. This will allow you to create or update contacts based on the data received from Instamojo.
Select ActiveCampaign from the action application list and choose the action event as ‘Create or Update Contact’. You will need to connect your ActiveCampaign account by providing your API key and URL, which can be found in the ActiveCampaign settings.
Enter the API key and URL in the respective fields in Pabbly Connect. Map the fields from Instamojo to ActiveCampaign to ensure that the correct data is transferred.
Once the mapping is complete, you can test the integration to ensure that the contact is created or updated in ActiveCampaign whenever a payment is made through Instamojo. This seamless integration is made possible by Pabbly Connect, ensuring that your marketing efforts are always aligned with your sales data.
5. Testing the Integration Process
After setting up the integration between Instamojo and ActiveCampaign using Pabbly Connect, it’s essential to test the entire workflow. Conduct a test payment through Instamojo and monitor the response in Pabbly Connect.
You should see that the contact details are successfully created or updated in ActiveCampaign. This confirmation indicates that your setup is correct and that Pabbly Connect is effectively managing the integration.
Verify that all fields are correctly populated in ActiveCampaign. Check for any errors in the Pabbly Connect dashboard.
Once verified, your integration is complete, and you can rely on Pabbly Connect to automate the process of updating contacts based on payment activities from Instamojo.
In this tutorial, we explored how to create or update ActiveCampaign contacts using Pabbly Connect for Instamojo payments. By following these steps, you can automate your workflow efficiently, ensuring that all payment-related contacts are managed seamlessly.
Utilizing Pabbly Connect for this integration not only saves time but also enhances accuracy, allowing you to focus on your marketing strategies while the automation takes care of the backend processes.
